0 members (), 45 guests, and 3 robots.
Topics128,049
Posts1,055,637
#817049 01/17/2012 5:47 AM
Ive been tossing the idea around of getting some adapters made to fit the 22.5 (big rig) wheel on my 52 2 ton. Has anyone done this or would anyone be interested in some if i could get them done for a reasonable price?
52' Chevy 6400 2 ton
Etraugott #817056 01/17/2012 7:33 AM
So are you going to take some 22.5 open center wheels and weld them to center of your old wheels. If so, I have done this on a brake drum lathe. I had a bunch of 8.25 open center wheels. If I were to do it again, I would probably use 7.50 wheels, but I sold all of them for salvage quite a few years ago.
crenwelge #817101 01/17/2012 2:34 PM
I was talking about the aluminum adapters like the guys are using now days to put the 22.5 on thier one ton duallys. This would allow me the put aluminum 22.5 on my truck. i know some people want to stay with the stock look, but i figured a few may be interested in these.
Etraugott #817109 01/17/2012 3:14 PM
I've looked at it before as well have others, there may be an old thread about them.
In my research (even made up an auto-cad drawing to see how it might work)there just wasn't enough room to make it all work without seriously offseting the wheel for the thickness of the spacer.
It works on 8 lug pickups because the 8 lug pattern fits well inside the big 10 lug wheel center. Not so with our 10 lugs on 7.25" pattern.
No reason you can't look at it again, you may come up with a workable solution that suits you.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #817137 01/17/2012 5:32 PM
Makes since. Will probably be more touble than its worth. Prob easier to do an axle swap and get better brakes in the process. Maybe in the future.
Etraugott #817160 01/17/2012 7:13 PM
Have you checked out the disc brake thread, sticky at the top of the big bolts section?
In that I outline a way of keeping your original 2 ton I-beam and swapping newer spindles and disc brakes.
Grigg
---All pictures---
Grigg #817163 01/17/2012 7:18 PM
Grigg do the wheels in your head ever stop turning grin
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
HevyHauler #817216 01/17/2012 10:28 PM
No. I wish I could follow through immediately with everything I think about.. it's confusing getting back into a project only when time allows here and there and remembering everything again.
Grigg
---All pictures---
Grigg #817219 01/17/2012 10:41 PM
Grigg today it is called A.D.D. or attention deficit disorder I too am afflicted one idea leads to ten others just one long string of thought. The difference between you and I is you seem to be able to focus long enough to take advantage of it. grin
user
Etraugott #817461 01/18/2012 6:32 PM
Crusing in the Passing Lane
I don't know what your bolt pattern is, however, there are 22.5's out there for just about any bolt pattern, starting w/ late '50's trucks when tubeless tires first came out.
EdPruss #825262 02/12/2012 12:58 AM
I contacted a guy that runs the www.americanforcewheels.com website and he custom makes wheels and adapters and he is very familiar with the issue we have. He said a set of adapters would run about $850 for a set and that would allow for the modern wheels to be mounted. I didn't want to pull the trigger on that. i eneded up getting a set of the original 22.5s and having them powder coated. Then mounted fairly new 9R22.5s on them.
Here is a pic of them:
[IMG]http://i107.photobucket.com/albums/m290/fclaridge/BusDreams.jpg[/IMG]
[IMG]http://i107.photobucket.com/albums/m290/fclaridge/NewWheelsandTires.jpg[/IMG]
1956 Chevy School Bus Superior Body
