0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | I'm resurrecting a 53 Big Bolt that has been resting for about 30 years, and obviously need to give the fuel tank a good cleaning. Any suggestions as to what I should, or maybe better yet, should not do. Thanks in advance.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | | | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | I assume the truck is in Arizona. Probably not a rust bucket. Remove the tank and and clean it out or take it to a radiator shop. Have boiled out and recoated if required. Blow out the fuel lines. Go for it and good luck. Larry | | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | Thank you. AZ it is. Where else can you park a truck in a field for 30+ years and it not rust away to nothing. The worst thing so far is the fact that the whole cab, frame rails, any horizontal part for that matter, is full of cholla cactus that the pack rats dragged in. The only rust is the outside cab bottoms, which should be easy enough to patch. | | | | | Joined: May 2009 Posts: 22 New Guy | | New Guy Joined: May 2009 Posts: 22 | I've never personally used the fuel tank cleaner from Eastwood, I've used allot of their other stuff and it's all been top notch, pricey but good quality. Might try that.
| | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | I used a cleaner and coating designed for tanks, the tank was in good shape, however after researching locally to have it dunked and cleaned it was the same price as a new tank, so that might be a consideration.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | For the price I'd replace it. But if ya want to de-rust the inside, remove the sending unit and fill it with 3 gallons of toilet bowl cleaner and water. Let it sit over night and rinse with plenty of water in the morning. Done it to many many motorcycle tanks, works like a charm. I use "The Works" bowl cleaner, super harsh!
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | .....take it to a radiator shop. Have boiled out and recoated.... Larry I'd follow Larry's advice. | | |
