2 members (51sub, Possum), 113 guests, and 4 robots.
Topics128,265
Posts1,058,364
Members48,485
#824034 02/08/2012 5:12 AM
I'm resurrecting a 53 Big Bolt that has been resting for about 30 years, and obviously need to give the fuel tank a good cleaning. Any suggestions as to what I should, or maybe better yet, should not do. Thanks in advance.
CmdrGeo #824039 02/08/2012 5:21 AM
Replace it,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #824052 02/08/2012 6:00 AM
I assume the truck is in Arizona. Probably not a rust bucket. Remove the tank and and clean it out or take it to a radiator shop. Have boiled out and recoated if required. Blow out the fuel lines. Go for it and good luck.
Larry
nels1954 #824145 02/08/2012 5:55 PM
Thank you. AZ it is. Where else can you park a truck in a field for 30+ years and it not rust away to nothing. The worst thing so far is the fact that the whole cab, frame rails, any horizontal part for that matter, is full of cholla cactus that the pack rats dragged in. The only rust is the outside cab bottoms, which should be easy enough to patch.
CmdrGeo #824227 02/08/2012 9:30 PM
I've never personally used the fuel tank cleaner from Eastwood, I've used allot of their other stuff and it's all been top notch, pricey but good quality. Might try that.
jimbo's46 #824979 02/11/2012 2:48 AM
I used a cleaner and coating designed for tanks, the tank was in good shape, however after researching locally to have it dunked and cleaned it was the same price as a new tank, so that might be a consideration.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
blanch53 #824998 02/11/2012 4:09 AM
For the price I'd replace it. But if ya want to de-rust the inside, remove the sending unit and fill it with 3 gallons of toilet bowl cleaner and water. Let it sit over night and rinse with plenty of water in the morning. Done it to many many motorcycle tanks, works like a charm. I use "The Works" bowl cleaner, super harsh!
1959 Shortbed stepside 1/2 ton project
[Linked Image from i236.photobucket.com]
nels1954 #825074 02/11/2012 2:14 PM
Originally Posted by nels1954
.....take it to a radiator shop. Have boiled out and recoated.... Larry
I'd follow Larry's advice.
