9 members (Gdads51, Rustnut, 3800GUY, KEVINSKI, Southerntruck, klhansen, dt235sd, Otto Skorzeny, Hotrod Lincoln), 69 guests, and 3 robots.
Topics128,079
Posts1,056,301
Members48,441
Just got the quote from a local radiator shop for recoring a 1937 Chevy radiator. Original style cellular core would be about $670 and newer style tubular core would be $590. It took me a while to find this radiator, which fortunately didn't cost much.
Question is, do I:
1) Bite the bullet and do the recore,
2) Keep looking for something that would work for less money
3) Buy a new one from ??
4) Get a less costly hobby
I want to keep the truck original, within reason. Any help is appreciated. Thanks.
1959 Chevrolet 3800 Pickup
1937 Chevrolet GC Panel
Can you still call it a barn find if it's your barn?
5) look wider geographically for another radiator company
or #1 as long as your tanks are still good.
But thats JMO, I'm sure there are still shops that don't try and make their rent up off of one client...
Give me ambiguity
or give me something else
I would definitely call around. You might try an old time roofing company. Those boys really know how to solder.
Kurt
id look around too. i got three of them recored with the newer style using existing tanks for around 400 each but that was a couple of years ago but less than four.
U.S. Radiator list one for a 38 truck starting at 460.00
...link...
Dont know if your 37 is the same but it might be worth a look.
I purchased a radiator from them directly for my 50.
I had mine recored but the top tank never would stay sealed for more then about a year. I think the sheet brass was just getting to thin and heat stress kept cracking the solder joint. I went with a aluminum replacement, but then my truck is not stock.
Joe
back yard wrench turner
Kerwin,
I bought a NOS radiator for my '38 from Alex Gerz Radiator in Lancaster, PA.
Price was very reasonable.
Call 717-392-6283 ask for Barry
His dad stockpiled them in the 30's and 40's.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I agree with JoeH. Sooner or later the old one will get you. I drove mine using original for several years with 4lb pressure cap but it gave up about 2 years ago. The local shop back then wanted $547 to redo mine. Soooo, I bought me a new aftermarket aluminum, at that time for $250 and it had the tranny cooler in the bottom and now I run a 7lb cap and have never had a moments problem out of it.
Oh, when the guy quoted me $547 understand my core was super nice and was NEW core when I built my 37.... all I wanted him to do was change the tanks which he had that would fit!!! I laughed out loud in front of him and layed the radiator back in my pickup. Maybe his girlfriend needed some money???
I had my radiator recored by a local shop here in Raleigh about 30 years ago. Was maybe around $100. Has never leaked, and still going strong.
Kurt
My new aluminum came with a 16 lb cap ! I went with a 14 just for piece of mind. This is something to conceder if you are having heating problems. A old, recored rad will not take that pressure.
Joe
