2 members (Guitplayer, 78buckshot), 253 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#821207 01/30/2012 6:03 PM
Looking for some advice please. Will be selling the original engine from our 1951 GMC 1/2 ton. I believe it is a 235? Not actually sure... lol (rookie) Anyways it only took about 10 minutes to get it to fun, that should be worth something!!? Was going to post it on craigslist etc. So what is it worth?
1951 GMC 5-window
9300 1/2-Ton
"Cinderella"
More pix of the old truck
...I hate to say it so I'll let someone else tell you!! Take a look around the swap meet in parts for sale. Just go back a ways and I'm sure you'll see what the engines are bringing....heck, you even find them in the freebie section.
The fact that yours runs does make a difference though.
Hey, welcome to the Stovebolt. I've met several of the B.C. Bolter guys and they are a super group.
Check out vancouver craigslist, they show up quite often with prices from free up to $500.You will have better luck selling it if the buyer can see it running.
Leo Offline
Moderator
Moderator
Welcome to the site. Just a few questions. Is your GMC made in Canada? If it is, you may well have a 235. If it's a low pressure engine, it won't be worth much, in fact, I took mine to the scrap yard. How do you know it's the original engine? Lastly, do you know the condition of the engine? Just a few variables there, but as mentioned, check what others are fetching. Good luck with it.
Leo
Thanks, it appears I have some homework to do.
1951 GMC 5-window
9300 1/2-Ton
"Cinderella"
Yes, it's made in Canada. By low pressure engine, do you mean splash lubricated vs pressure lubricated? This particular engine has the partial flow oil filter, and an oil pressure gauge on the dash that works when it's running. Could do a compression test to confirm a little more about the internal condition.
1951 GMC 5-window
9300 1/2-Ton
"Cinderella"
What are the plans for the truck? You might want to drive it around with the old engine first, before you yank it out.
For what its worth, I bought a complete 216 in Langford for $75. I was told it was running, but never checked it out, as I just wanted spare parts to keep my truck running. It came with gauges, and a few starters and generators too.
If you post up some pictures, and do a compression test, and see what the oil pressure is when the engine is hot (running for say 20min), and see whether it smokes, you'll have a better idea. Someone might be interested in the engine just to use as a "runner" if its not smokey, etc.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
If the engine is truely the original engine for the truck then it has value only while it is in the truck it left the factory with. Once it is pulled and put up for sale, the value is nill. And, in my opinion the truck value is diminished. Unless, of course, the truck is hotrodded or resto modded.
