3 members (Nick in Manitou, Wally / Montana, 1 invisible), 58 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
#820019 01/26/2012 10:01 PM
Anyone have a good source (net or otherwise) on a step by step instruction on how to rebuild drum brakes? Illustrations would be great.
I've got a '64 C-10 and I'm looking to replace my m/c with a dual chamber m/c with a disc/drum power unit.
'64 C10 1/2 ton fleetside
BrianW #820023 01/26/2012 10:17 PM
Find a service manual for your truck, like this one, to explain the procedures. Take off the drums off both sides, but, only take the shoes off one side so you can see the other side for reference. Clean everything real good and repack wheel bearings and seals while you are at it. Let us know how you are coming along.
http://www.gregsonline.com/eshop/Shop_Manuals/64TSM.htm
Most of the parts you can buy at local parts stores. Check NAPA for new drums if they are out of spec.
Builder #820024 01/26/2012 10:19 PM
Thanks, Builder! I've got the shop manual coming the mail in the next few days.
BrianW #820252 01/27/2012 5:47 PM
You state that you are going to replace your mc with a disc/drum power unit. That may not work so well. It sounds like you are going to rebuild the drum brakes. The booster/dual mc is a great idea and is a vast improvement but you will need to get a booster/mc combination that was designed for drum brakes.
There are a number of aftermarket suppliers that offer these units.
Fred
Thanks Fred ... I'm really just in the process of figuring all this out, so any advice from Stovebolters is appreciated. Brakes failed again last night. The pedal just went straight to the floor. Checked the m/c and just air in there. darn ... I was watching the fluid levels like a hawk. Was a couple of miles from home, so added some brake fluid, pumped the brakes a bunch and got a little pressure, so drove home slowly. Very slowly. This truck ain't leaving the driveway again until this is fixed for sure. I can't risk it.
Figure I'll test the m/c to see if it is bad (not that I know how to do that either, but hey ... got to learn sometime) and make a list of other components so that I can figure out what exactly the problem is here by a process of elimination - before I start replacing anything.
Any advice on what that list should look like (in order of priority) would be really, really helpful.
BrianW #820287 01/27/2012 8:04 PM
back yard wrench turner
1st you need to find the leak. It could be the Wheel cylinders.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
For as cheap as you can buy the parts for the truck, it might be worth buying new or remaned parts instead of rebuilding the parts.
http://www.car-stuff.com/1964chevro...tc10pickup19611973centricce135.640064614
http://www.car-stuff.com/1964chevro...hevroletc10pickup19611970prontoprbd81061
If one cylinder has failed, others can't be far behind. Replace the entire brake system at once and get it over with.
Cletis #820303 01/27/2012 9:37 PM
Builder, thanks much for the links! Cletis, your logic is sound. Wayne, thanks for the starting point.
Part of the problem for me is that I live in Oregon ... so it rains for about 5 months solid. This weekend looks like we'll actually get some sun, so I'll be able to visually inspect the lines and the drums.
Cletis #820320 01/27/2012 10:20 PM
I agree. It was my intention to say this....but, I guess I didn't.
If the fluid disappeared from the MC and there are no visible leaks on it, for sure you have a leak somewhere else. I would also suggest and end to end rebuild of the hydraulic brake system.
1951 1 Ton Completed
It was a bad m/c and a hole in the brake line that connected the front driver's side wheel to the front passenger side wheel - i.e. under the engine. Because the m/c was bad, there wasn't enough pressure to really spray the brake fluid through the hole. Once a good one was in, the whole made itself known.
For how hard those bolts on that brake line were to get off, I'd say they hadn't been touched since 1963.
Total cost of the job was about 50 bucks. Nice. Still have to go back and rebuild the drums, but it feels good to know where the failure in the system was.
Thanks for all that gave advice.
BrianW #820907 01/29/2012 9:25 PM
What I said about cylinder holds true for brake lines also. They rust through from the inside.
Cletis #822140 02/02/2012 6:28 AM
Brian, If memory serves, the front/rear C10 drums are the same and have been since '55 or so. They're CHEAP, too. I just bought a pair for $29.00 each. Unless your drums only need slight turning, I'd much rather replace them. Remember who's backside in in the seat!
best wishes,
Les
For as cheap as the parts are for these trucks, I wouldn't even mess around. I would replace all components and be done with it.
