1 members (GRNHydra),
161
0
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I have my rocker arm assembly apart and am cleaning the sludge out of it. The upper side of the head has a lot of sludge sitting in it and I've been able to mop some of it out with rags but I was wondering if there was something I could spray it with to help loosen it up. I know whatever I use will wind up in the crankcase but I will change the oil. A few weeks ago I ran a 50/50 mixture of oil and automatic transmission fluid through it to clean it but there is still this stuff sitting where the rocker arm assembly goes.
1956 Chevy 3200
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Joe, I've used spray can of brake cleaner and a brass brush with success. It'll take your breath away, so use good ventilation.
Drew
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Soak them in a bucket of diesel or another cleaner. It will soften up the crud and you'll have to remove the stuff with a brush.
Jeff | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i remember doing that on my 228 when it was in my 40. i also did the lifter galley while i had it open with the pan off. the rockers assembly looks good along with the pipe. did you remove the plugs on the end of the pipe and clean that out? lots of gunk and sludge in there. i cleaned like i was cleaning a rifle. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | If you mean the hollow rocker shaft, yeah. I have it soaking in gasoline at the moment. It had a lot of crud inside it and I didn't have a wire brush to run through it so I'm letting it soak. Those rifle cleaning kits a very useful for this kind of job.
1956 Chevy 3200
