5 members (Gdads51, Otto Skorzeny, Southerntruck, fonz8261, festerhairball), 75 guests, and 2 robots.
Topics128,094
Posts1,056,048
Members48,433
#810297 12/25/2011 8:08 PM
I have a later model van column, put a kit on to install power steering box, I need to connect the two. Can you use a rigid coupling or is there too much missalignment? Or a u joint type. I bought a Chev. intermediate shaft on Ebay but I needed 3/4" 36 spline. Any way to convert this. thanks
Look up "Borgensen joint" and decide what you have at each end. The joint is a mini U-joint with one design on one end and another on the other end, made for adapting steering components. Most hotrod/custom shops will have them,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
What Scott said. They'll have you on track in no time.
Tramp
dj durant
More pix on Flickr
On my 65 GMC I used a steering box off a 75 Chevy Truck with the REZ kit and picked up a column with the shaft off a 75 Camaro (non tilt), it fit like a glove. Broke the plastic rivit loose and so the shaft would move and fabbed up the mount under the dash, when it was all done it wes within 1/4" from the stock.
You Learn more Listening than Talking
