7 members (JW51, Hotrod Lincoln, Wally / Montana, texas46, TooMany2count, Jaison, 1 invisible), 120 guests, and 2 robots.
Topics128,082
Posts1,055,961
Members48,430
does anyone make patch panels to close up the 2 extra windows in the five window cab? personally I like the 3 window better.
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
I don't think I have ever seen or heard of patch panels for the corner windows. It's just not popular. Many folks want to go the other way. I think a lot of people would trade you cabs.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
H Online: Content
I know a man who swapped the entire assembly from the beltline up to get a 5-window. That's one option, but you'd need to find a donor 3-window cab with a good upper section, maybe one with serious rust problems at the bottom.
I have a nice 3 window cab I'll trade you if you want to make a trip to Colorado Springs.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
If it is rust free I can come up with a 3 window here in Dallas for the swap
Dennis
mo Offline
i like the three window way better to. cleaner looking cab as far as i am concerned. you could form a patch panel out of some flat steel. find a comparable curve like a tree or something and heat it up and work it to the right shape. of course there is always an english wheel. good luck.
MO's 1951 chevy 3100 resto mod project
I have a three window too the cab is junk but these areas are still good I may cut them out and fab them in place on the five window
My Project Bolt
The inside of that fill would make a great place for some 6x9 speakers.
1953 Chevrolet 3600
Like the guys say,I think you're on your own regarding patch panels,cutting them from a junk cab is by far your best option,that way you know the contours should at least be close.
This is the first time i've seen someone wanting to go from 5 to 3 windows! grin
More pix on Flickr.
I know a guy who has made two cabover 2 tons into a 1/2 ton w/ short beds and added corner windows but not the other way round.
that extra visibility is just great to have
Jim & Caroline
I have a 3 window cab that the bottom and firewall are in pretty bad shape but the top is in real good shape. I was going to scrap the cab. I could cut the top part off. But I don't know if it would be to big to ship UPs or not.
Here's an example with pictures of the conversion from the HAMB:
http://www.jalopyjournal.com/forum/showthread.php?t=568254&highlight=my+crazy+project
You Tube
Thanks for that Curt, I've seen this build in the HAMB,I guess I should pay more attention!
The guy's doing a real nice job on the whole truck,not just the corner glass.
More pix on Flickr.
mo Offline
you could take the advice i just got for fillin some holes on my frame. could use some kitty hair bondo with fiberglass reinforcement then sand them smooth and paint. i wouldnt but that the advice i got. lol
Mo, I remember a few years back I saw someone skim some old newspapers with bondo and paste them over the rear door window openings in a delivery van..........
Between all the bondo and the time sanding it,it would have probably been cheaper welding in metal!
More pix on Flickr.
Well, here's another with 3 window preference.
~Jim
V
V Offline
My 2 cents. Make an endview template that matches the curve of the excisting window you want to cover,this can be used as a curvature gauge.
Take the gauge to a sheet metal shop and have them run new sheet metal through their rollers until the curve matches the gauge. They should be able to make make 2 pieces slightly larger than the window. For the inside shell it should be the same curve. So if you had 4 of them, you'd have 4 nice patches to do the job. Hope this helps.
mo Offline
ive also seen people take and screw galvanized sheet metal over window openings they didnt want. lol
Would that have been on a double-wide?
~Jim
mo Offline
no actually on a window van.
One more for the 3 window cab. It's a much cleaner look. Corner windows are useless, unless you can spin your head completely around.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Yeah, and it gets harder as we grow older.
~Jim
I like both cabs. 5 windows are nice for driving, but 3 windows are cool.
If you like old trucks (we all do) the 3 window looks older. I am feeling more like 3 window every day. thumbs_up
~Jim
