3 members (GradyB, 60steve, Bill Hanlon), 187 guests, and 4 robots.
Topics128,204
Posts1,057,289
Members48,467
but have modern safe tires what would you get? 16 inch.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I decided to sell my bias ply and go with radials. I bought Bridgestone Ecopia EP02. They have the skinny look and correct diameter. The ol' 38 ain't nervous goin' down the road, good and smooth. Much more enjoyable drive now.
How wide are your rims? I want to get new solid rims and get radials. Sizes are 16X6 and wider.
Ex Hall Monitor
Ex Hall Monitor
Coker makes a 600x16 radial with the same diameter and cross section as the bias ply but they are EXPENSIVE. A 185/85r16 is a close match but no one sells that size in the US that I've been able to find. Diamond Back sells a 195/80r16 that has the right diameter but is wider and could cause clearance issues in some cases.
The Ecopia is a 195/80R 16. I have them on 5" wide wheels. If you don't change backspacing or wheel diameter (as compared to stock wheels), you should not have clearance issues. I looked at Coker - but man, he is real proud of his stuff !!
LT215R85 16" Cooper SRM II radials
Tracy, I've got to say that '38 of yours is a fine looking truck. In my opinion the '38 is the best looking pickup Chevy ever made, and yours is a terrific example.
My toys:
'41 Chevy Model AL 3/4 Ton
'40 Chevy Model KD 3/4 Ton
Hinomoto 209N Tractor/Backhoe
Norwood LM2000 Sawmill
PJ 16' Trailer
and a Brand New Shop!
Be what you is, not what you ain't, 'cause when you is what you ain't, then you ain't what you is.
Tim, Are these tires on the stock '54 rims? Tubes? Any other details?
Leo Online: Content
Moderator
Moderator
That would be my choice too, available at tire stores that carry Coopers.
ODSS Lawman
ODSS Lawman
IF your rims are in good condition, you will not need tubes. I run Diamond Back Smoothies on my truck and they run great!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
The set I have on my Suburban has radial-tubes and they have worked fine for over 7 years (with high speed driving).
My rims are all stock 16"x4.5 truck rims.
The Cooper dealer installed the tires/tubes and balanced them. He also recommended using plastic sleeves/protectors where the valve comes through the rim.
The next set that I buy for the 54 1/2 ton pickup I am restoring will have no tubes - these wheels are in beautiful conduction and I have had them trued and powder-coated. And, I will probably use balancing beads rather conventional weight-balancing ( here's a discussion on balancing beads).
The cooper smrII are no longer available. now called star fire.
2017 Buick Encore
See more pix
Thanks, Ron.
Cooper's website does not list that line (Starfire SF-510 LT) and it still lists the SRM II. My guess is that their website is out of date.
