3 members (Jon G, Joe H, 1 invisible),
137
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,198 Posts1,057,272 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | but have modern safe tires what would you get? 16 inch.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | I decided to sell my bias ply and go with radials. I bought Bridgestone Ecopia EP02. They have the skinny look and correct diameter. The ol' 38 ain't nervous goin' down the road, good and smooth. Much more enjoyable drive now. | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | How wide are your rims? I want to get new solid rims and get radials. Sizes are 16X6 and wider. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Coker makes a 600x16 radial with the same diameter and cross section as the bias ply but they are EXPENSIVE. A 185/85r16 is a close match but no one sells that size in the US that I've been able to find. Diamond Back sells a 195/80r16 that has the right diameter but is wider and could cause clearance issues in some cases.
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | The Ecopia is a 195/80R 16. I have them on 5" wide wheels. If you don't change backspacing or wheel diameter (as compared to stock wheels), you should not have clearance issues. I looked at Coker - but man, he is real proud of his stuff !! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | LT215R85 16" Cooper SRM II radials
| | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | Tracy, I've got to say that '38 of yours is a fine looking truck. In my opinion the '38 is the best looking pickup Chevy ever made, and yours is a terrific example. | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Tim, Are these tires on the stock '54 rims? Tubes? Any other details? | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | LT215R85 16" Cooper SRM II radials That would be my choice too, available at tire stores that carry Coopers. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | IF your rims are in good condition, you will not need tubes. I run Diamond Back Smoothies on my truck and they run great!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Tim, Are these tires on the stock '54 rims? Tubes? Any other details? The set I have on my Suburban has radial-tubes and they have worked fine for over 7 years (with high speed driving). My rims are all stock 16"x4.5 truck rims. The Cooper dealer installed the tires/tubes and balanced them. He also recommended using plastic sleeves/protectors where the valve comes through the rim. The next set that I buy for the 54 1/2 ton pickup I am restoring will have no tubes - these wheels are in beautiful conduction and I have had them trued and powder-coated. And, I will probably use balancing beads rather conventional weight-balancing ( here's a discussion on balancing beads). | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | The cooper smrII are no longer available. now called star fire.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, Ron.
Cooper's website does not list that line (Starfire SF-510 LT) and it still lists the SRM II. My guess is that their website is out of date.
