| | | Forums66 Topics128,186 Posts1,057,305 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | I need to add a few individual leaf springs to my 37 Chevy 1/2 ton that the previous owner removed. Anyone know of places in central TX (approx between Waco & Austin) that could manufacture and/or install them? | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I don't think there any old spring shops in Austin. Ace Spring in San Antonio is the only spring shop that I know of. They looked like they had been there 100 years ago when I first started going there over 50 years ago. | | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Thanks. I'll take a look at them. I'm not confident enough in my truck to drive it to San Antonio yet though. | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | Why not use Chevy S-10 leafsprings as I did?
When mine needed to be changed and no reasonable replacements could be found my mechanic at the time suggested I measure those that came off the '37 and told me that S-10 leafsprings would fit and they did... just a thought as S-10 parts are readily available and are quite cheap... Hope that helps! | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | waco spring and brake.i watched them make springs from scratch.
1963 c10 | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | If you're willing to drive to Fort Worth, try Champion Spring on Henderson (Not Ray's on I-35).
I've only used them for spring components, but they have a good reputation for leaf spring work.
regards, Leon | | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Did you have to modify them? I've never worked on leaf springs before, but I would assume that if the length, width and thickness of an individual leaf were similar to that of the corresponding original leaf on a 37 it would work. If S-10 springs will fit that would be great because I only need a few individual leafs, not a whole new assembly. | | | | | Joined: Nov 2011 Posts: 3 New Guy | | New Guy Joined: Nov 2011 Posts: 3 | I got brand new leaf springs made at GM for my 1940 gmc 1 ton dually. GM has 3 guys that do nothing other than making the antique springs from the old shop drawings. I went through Thurston Springs in Richmond Virginia. for all 3 sets of springs it cost $1300. Dennis over there is the man to talk to. | | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Reference the specs TooMany2count shows under "click again", does anyone know what "working height" means and how one would go about measuring it? | | | | | Joined: Feb 2000 Posts: 5,242 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,242 |
| | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | I made a similar post in the general forums but I wanted to reach out to the Texas Bolters in particular. I finally took my truck to Waco Spring and Brake today to fabricate my missing leaf springs, but the tech (Jerry) didn't have info on the arching for a 37 1/2 ton's front and rear leaves. I provided him the specs (that TooMany2Count links to above) but he said it was still not the info he needed; I'm sure he can figure something out on his own but I'd like to give him something definitive.
Any idea where I can find "arching" info?
Thanks, Mike | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Mike, a phone call to Eaton Spring MIGHT be of help if you talk nice to them. Worth a try. | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | think i am going to have my front springs flattened and the eyes reversed on my 37.. it just ride way to high for my taste :)but they might have to make a new top spring if they do that your welcome to atleast those
1937 1/2 ton
