Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#81196 08/07/2007 4:46 AM
Junior Member
Junior Member
I have been trying to put my three speed tranny back into my 65 truck. First problem was it would not go in all the way, I realized the pilot bearing was not in all the way. So I pressed it all the way in so it bottoms out, now the tranny still will not go in all the way! The bearing and clutch are all new. The tranny is about a little more than a 1/4 inch from the bell housing and I cannot for the life of me get it all the way in.
Any ideas?
Any ways to force it in with the bolts?
#81197 08/07/2007 5:07 AM
Whatever you do, don't force it in. Probably a good time to go back and look at everything again.
Make sure the nose of the transmission will fit in the pilot bushing, maybe the bushing got banged up and has a bur on it or is the wrong one. Make sure the clutch disc is lined up with the pilot bushing. Check to see that the release bearing will slide on the collar easily. Make sure the release fork is not binding on the pivot or on the release bearing. Hope this helps, Fred
#81198 08/07/2007 1:33 PM
as Fred said ,ALSO are ya using a alighnment tool for this project to keep everything lined up ?
1952 Chevy Shortbed
Photos in Photobucket
#81199 08/08/2007 12:19 AM
Junior Member
Junior Member
Yea, Ive done all that. Im going to give it, and me, a rest for today. Its probably something really stupid on my part, but I will try again tommorow, and hopefully I can figure it out and get it to work.
#81200 08/08/2007 3:20 AM
Is this a new trans or the same one that came out going back in?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#81201 08/08/2007 3:32 AM
Junior Member
Junior Member
It is the same one that was removed
#81202 08/08/2007 3:50 AM
Get the trans as close as possible without forcing anything, and install the bolts just snug, don't try to force things into place. Then depress the clutch pedal. If there's a slight misalignment, releasing the pressure plate will allow everything to fall into alignment. If you give the trans a little shake and push from behind while the clutch is released, it should fall right in. If not, remove the clutch and pressure plate, and see if the trans will bolt up without the clutch installed.
One mistake that happens occasionally is the clutch disc gets installed backwards. The hub with the torsion springs in it needs to face away from the flywheel. Yes, it can be installed either way, but it only fits right one direction.
