6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#810899 12/28/2011 5:45 AM
I need a new master cyl for my 52 2 ton. Was wondering if anyone has upgraded to a dual resivor master cyl for saftey reasons.
52' Chevy 6400 2 ton
Chances are your 52 has a Hydrovac Booster which makes it hard to "split" the circuit.
I have heard of guys adding a second Hydrovac (one for each circuit), but I have no knowledge of how this worked when done.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Yes, thats the difficult part. I was thinking like fabing up a newer master with a booster on it. But then im not sure if i would need to stick with the same bore size. Just curious if anyone has done anything like this with success
I wouldn't waste the time, unless your running a 454 and driving 70 MPH the orginal set up works just fine.
Im sure they will work fine, i was just thinking about it for saftey if you get a leak you will still have front or rear brakes. I will prob just go back with the original setup and replace all lines and hoses.
I put a booster and a master from a 70 C10 truck under the floor. A lot of fab work but the brakes never worked better, if you're capable, I would recommend it,
Scott
PS...some will try to say that a C10 master is too small because of it's bore when in reality, it's bigger (because the system is split in half)
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Hey Scott...which truck did it go in and do you have any pix? I am looking for a dual pot solution for my '46 1.5 ton. Have zero faith in the old single pots...any leak, anywhere = zero stopping.
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
Tango #811185 12/29/2011 3:10 AM
No pictures, the truck is now retired due to rust issues. I put it in my 48 1 1/2. I just made an "L" shaped bracket that attached to the original masters location making sure there was enough room for the booster. I then cross braced it to beef it up, mounted the master and made an adjustable pedal rod. Split the front and rear brakes to the master and spent a good long time bleeding and adjusting. Since my truck went to 12 volts, I also plumbed in a pressure switch for the brake lights. This was close to 20 years ago and the truck still has brake pedal!
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
Thanks Scott --- I will have to take a look at that combo and see if it looks transplantable to my 46. Not sure what significant differences there were between the Art Deco series and the Advanced Designs but I'm hoping for an "easy" fix (ya, right).
Had a mid '60's Furd pickup that wound up with a crumpled fender when a rear wheel cylinder went South. Lucky for me it was barely rolling when it all went away. Swapped it for a dual and swore I'd never challenge that particular demon again.
