7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | Can anybody tell me what this number tells about this engine I have. The number is T0208D. IT is stamped on the front passenger side of the engine. I ran the casting number on the back of the engine on the drivers side 3794226 and it says 1958-63 truck 283. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | 3794226 = 1958-62, 283, 2 bolt main, truck
T0208D (engine assembly plant code); T = Tonawanda plant 02 = second month (February) 08 = 8th day of the month D = 8 cylinders
A date code may be cast into the block near the other casting number you gave, and give you the year the block was cast. | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | Thanks I will look for other numbers when I get home from work. | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | I looked on the front of the engine where the stamped numbers were and there were no more numbers. So I guess I cant tell the exact year the engine is. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Look near the "casting" number (3794226) on the rear of the block. Also close to the distributor hole. There is also a cast mark that looks like a clock. A series of "cast" letters and numbers will make up the date code. example B214 | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | Thanks I will look in those places and let you know what I find | | |
