0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#810768 12/28/2011 12:24 AM
7
7 Offline
Can anybody tell me what this number tells about this engine I have. The number is T0208D. IT is stamped on the front passenger side of the engine. I ran the casting number on the back of the engine on the drivers side 3794226 and it says 1958-63 truck 283.
3794226 = 1958-62, 283, 2 bolt main, truck
T0208D (engine assembly plant code);
T = Tonawanda plant
02 = second month (February)
08 = 8th day of the month
D = 8 cylinders
A date code may be cast into the block near the other casting number you gave, and give you the year the block was cast.
7
7 Offline
Thanks I will look for other numbers when I get home from work.
7
7 Offline
I looked on the front of the engine where the stamped numbers were and there were no more numbers. So I guess I cant tell the exact year the engine is.
Look near the "casting" number (3794226) on the rear of the block. Also close to the distributor hole. There is also a cast mark that looks like a clock. A series of "cast" letters and numbers will make up the date code. example B214
7
7 Offline
Thanks I will look in those places and let you know what I find
