1 members (TexasJim50), 119 guests, and 2 robots.
Topics128,265
Posts1,058,364
Members48,485
#80730 08/01/2007 9:06 PM
I had a question for the old 283 V-8 guys.
I am restoring this '66 fleetside and on the very back of the engine block by the distributor hold is a very small pipe coming off a brass fitting. Since the motor was out of the truck, I do not know what it is for. Any help is appreciated. Is it vacuum or for some gauge. maybe temp
sovagary
GS
#80731 08/01/2007 9:15 PM
Gary,
I'm old, but I don't know if I'm a 283 guy or not! For some reason, my brain cells tell me this was a oil pressure tap location. It might have come from the rear cam bearing and gone to a gauge, or had a sending unit in it. I could be wrong on this. smile
Stuart
#80732 08/01/2007 10:38 PM
Yep, oil pressure port,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#80733 08/02/2007 2:57 AM
Thanks. So it goes to the oil gauge in the dash, but the other end has a brass fitting also that attaches to rear of the engine and that in turn must go down to the cam bearing area? I guess it will work when I get it all back together.
Gary
GS
#80734 08/02/2007 4:08 AM
Do you have a picture? If it has two fittings coming from the same port, one is for the mechanical gauge and the other would be for an idiot light showing no oil pressure. A buddy of mines' Vette had that dual set-up,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#80735 08/02/2007 3:31 PM
NO there's only one fitting going into the block.
I would do a picture, but that would mean I would have to actually learn how to put it on this site. which is probably a real project on its own. I did take lots of pictures for my reference when putting it together.
Gary
GS
#80736 08/02/2007 4:10 PM
Gary,
I think this may have gotten confusing. The hole in the block is merely a access point to the oil system. You can use it for whatever you want. You can plug it, run a mechanical gauge off of it or stick a electrical sending unit in it. It doesn't do anything....it's just there!
Stuart
#80737 08/03/2007 3:02 AM
Quote
Originally posted by atomarc:
Gary,
Stuart
Exactaly
1970 C50 dump! saving orphans from the CRUSHER
#80738 08/03/2007 2:33 PM
OK, but don't I need to plug this into my gauge in the dash when I get the cab back on? the truck has an oil gauge.
Gary
GS
#80739 08/03/2007 2:39 PM
Gary,
Only if you want the gauge to work! eek
Stuart
#80740 08/03/2007 8:14 PM
my 283 has an oil pressure gage line attached there.
Another quality post.
Real Trucks Rattle
