8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible),
99
7
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80730 08/01/2007 9:06 PM | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | I had a question for the old 283 V-8 guys. I am restoring this '66 fleetside and on the very back of the engine block by the distributor hold is a very small pipe coming off a brass fitting. Since the motor was out of the truck, I do not know what it is for. Any help is appreciated. Is it vacuum or for some gauge. maybe temp sovagary
GS
#80731 08/01/2007 9:15 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Gary, I'm old, but I don't know if I'm a 283 guy or not! For some reason, my brain cells tell me this was a oil pressure tap location. It might have come from the rear cam bearing and gone to a gauge, or had a sending unit in it. I could be wrong on this. Stuart | | |
#80732 08/01/2007 10:38 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Yep, oil pressure port, Scott | | |
#80733 08/02/2007 2:57 AM | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Thanks. So it goes to the oil gauge in the dash, but the other end has a brass fitting also that attaches to rear of the engine and that in turn must go down to the cam bearing area? I guess it will work when I get it all back together. Gary
GS
#80734 08/02/2007 4:08 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Do you have a picture? If it has two fittings coming from the same port, one is for the mechanical gauge and the other would be for an idiot light showing no oil pressure. A buddy of mines' Vette had that dual set-up, Scott | | |
#80735 08/02/2007 3:31 PM | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | NO there's only one fitting going into the block. I would do a picture, but that would mean I would have to actually learn how to put it on this site. which is probably a real project on its own. I did take lots of pictures for my reference when putting it together. Gary
GS
#80736 08/02/2007 4:10 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Gary,
I think this may have gotten confusing. The hole in the block is merely a access point to the oil system. You can use it for whatever you want. You can plug it, run a mechanical gauge off of it or stick a electrical sending unit in it. It doesn't do anything....it's just there!
Stuart | | |
#80737 08/03/2007 3:02 AM | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Originally posted by atomarc: Gary,
Stuart Exactaly
1970 C50 dump! saving orphans from the CRUSHER
#80738 08/03/2007 2:33 PM | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | OK, but don't I need to plug this into my gauge in the dash when I get the cab back on? the truck has an oil gauge. Gary
GS
#80739 08/03/2007 2:39 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Gary, Only if you want the gauge to work! Stuart | | |
#80740 08/03/2007 8:14 PM | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 | my 283 has an oil pressure gage line attached there.
