8 members (68ironhead, GMCJammer51, Bill Hanlon, Gdads51, TrknGMC, 53 green 1- ton, msmall, 1 invisible), 181 guests, and 2 robots.
Topics128,086
Posts1,056,094
Members48,434
#802030 11/30/2011 1:10 AM
Where can I get a 10-3/4" clutch and pressure plate? Napa cannot get one. Is a rebuilt one from Jim Carter the only option? Thanks,
Josh
Pa Farmer #802664 12/01/2011 9:58 PM
I think you'll find they don't sell them quite like the old ones here is another alternative: www.ClassicParts.com the whole assemmbly for a 235 is $224 Part number 90-007K. This is probaly what you can find at the local NAPA using these corrected measurements. It will fit fine on your flywheel.
Brad Allen #802684 12/01/2011 11:41 PM
The picture on their website shows a 6 bolt pressure plate, mine has a 9 bolt pressure plate. Is that a generic picture of a clutch kit? Did the later 235's have a 9 bolt flywheel? Thanks,
Josh
Pa Farmer #802738 12/02/2011 2:54 AM
Do you have the original clutch and pressure plate? If so, Napa can send them out to be rebuilt for a pretty decent price.
I had mine rebuilt and relined for less than $200 for a 10 3/4" clutch when I worked on my COE.
I believe some of the other vendors also carry them.
Jeff
My 1953 Chevrolet
1947.1 Gallery
The flywheel has a date code cast on it. Letter and numbers. Example B 58 = Feb. 5 , 1948. If the fly wheel has the 6 hole pressure plate then that date code could be Feb.5, 1958. It can be confusing as to the generation '40's,'50's'60's. Early flywheel wheels ( at least thru and including 1948 had 9 bolt pressure plate) for the 10 3/4 " clutch on the 3800 series (1 ton). I bought a new clutch disc from NAPA and had the pressure plate rebuilt at an independent clutch shop.
Moderated by  Dusty53
