1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 54 | Where can I get a 10-3/4" clutch and pressure plate? Napa cannot get one. Is a rebuilt one from Jim Carter the only option? Thanks, Josh | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I think you'll find they don't sell them quite like the old ones here is another alternative: www.ClassicParts.com the whole assemmbly for a 235 is $224 Part number 90-007K. This is probaly what you can find at the local NAPA using these corrected measurements. It will fit fine on your flywheel. | | | | | Joined: Jan 2008 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 54 | The picture on their website shows a 6 bolt pressure plate, mine has a 9 bolt pressure plate. Is that a generic picture of a clutch kit? Did the later 235's have a 9 bolt flywheel? Thanks, Josh | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Do you have the original clutch and pressure plate? If so, Napa can send them out to be rebuilt for a pretty decent price.
I had mine rebuilt and relined for less than $200 for a 10 3/4" clutch when I worked on my COE.
I believe some of the other vendors also carry them.
Jeff | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | The flywheel has a date code cast on it. Letter and numbers. Example B 58 = Feb. 5 , 1948. If the fly wheel has the 6 hole pressure plate then that date code could be Feb.5, 1958. It can be confusing as to the generation '40's,'50's'60's. Early flywheel wheels ( at least thru and including 1948 had 9 bolt pressure plate) for the 10 3/4 " clutch on the 3800 series (1 ton). I bought a new clutch disc from NAPA and had the pressure plate rebuilt at an independent clutch shop. | | |
