0 members (), 44 guests, and 4 robots.
Topics128,077
Posts1,056,013
Members48,433
#799532 11/20/2011 11:44 PM
I recently found some real mildew on the underside of my bed wood on the '53 bolt. There also appears to be some on the top as well. So, I am ready to put in new boards, but what the heck caused the mildew and how can I prevent it in the future? I will be putting 2 coats of urethane on the boards after staining them.
Shmoo #799535 11/21/2011 12:28 AM
Storing them in a damp dark location and exposing them to spores causes mildew.
Keep them in a dry location exposed to the light of the day in the future.
Just as simple as that.
dg
Denny G
Sandwich, IL
ODSS Lawman
ODSS Lawman
Mold needs 3 things to grow..
1. moisture
2. pourous surface to grow on
3. lack of light
Since wood is a great thing to grow mold, the best thing you can do is try to keep in dry.
Having a good coat of urethane or other sealant is our best barrier of protection. I had mildew on my bedwood when I did my engine swap. I just resanded and started over.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #799609 11/21/2011 3:42 AM
Don't put "plain" urethane on them or it will crack and then turn black. Be sure its "spar" urethane like Helmsman Spare urethane.....or check out Mar-K's site on their test of different finishes.... .and I'd do 3 or 4 coats and be sure to soak the ends overnight standing in a pan of the finish. Hope this helps get you what your looking for.
Best formula to remove mold is to spray it with plain old household bleach. If you keep it outside under a tree sitting in a pile of wet leaves you'll get a lot of mold.
~Jim
