0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 86 New Guy | | New Guy Joined: Jun 2005 Posts: 86 | I recently found some real mildew on the underside of my bed wood on the '53 bolt. There also appears to be some on the top as well. So, I am ready to put in new boards, but what the heck caused the mildew and how can I prevent it in the future? I will be putting 2 coats of urethane on the boards after staining them. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Storing them in a damp dark location and exposing them to spores causes mildew. Keep them in a dry location exposed to the light of the day in the future. Just as simple as that.
dg
Denny G Sandwich, IL
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Mold needs 3 things to grow..
1. moisture 2. pourous surface to grow on 3. lack of light
Since wood is a great thing to grow mold, the best thing you can do is try to keep in dry.
Having a good coat of urethane or other sealant is our best barrier of protection. I had mildew on my bedwood when I did my engine swap. I just resanded and started over.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Don't put "plain" urethane on them or it will crack and then turn black. Be sure its "spar" urethane like Helmsman Spare urethane.....or check out Mar-K's site on their test of different finishes.... .and I'd do 3 or 4 coats and be sure to soak the ends overnight standing in a pan of the finish. Hope this helps get you what your looking for. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Best formula to remove mold is to spray it with plain old household bleach. If you keep it outside under a tree sitting in a pile of wet leaves you'll get a lot of mold.
~Jim
