1 members (RLB), 81 guests, and 1 robot.
Topics128,162
Posts1,056,940
Members48,458
What type oil do you guys use in your air cleaner?
thanks.
just yer runa the mill 30 wt, or 10-30, or 10-20, or 10-40 ... whatever's on hand ... no moving parts! grin
The Chevrolet Shop Manual suggests 50 weight oil but most likely any oil is OK. I have been using 50 weight oil.
When I worked for Std Oil, we sold 55 gallon drums of Zerolene 50 weight just for logging truck oil bath air cleaners. The plan of the day was CHEAP and THICK.
Stuart
Most all of the Chevy dealerships and service (gas) stations back in the day just used readily avalable #30 motor oil right off the rack. I worked and hung around in a lot of them in the late 50's and 60's. Generally just any heavy wt. oil will do just fine, it's a long way from rocket science!
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
In the day, G.M. recommended 50 weight.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Why would you want "thick" oil? It's going to thicken up as it collects dust and dirt. I would think a 10W- whatever would be better these days,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Scott,
I'm not sure why 'thick'. Maybe there was a sloshing consideration. As the shop flunky I serviced the air cleaners. The oil reservoir had a level mark stamped into the pan and I was told never to overfill them. I assumed if it were overfilled the excess oil would choke off the incoming air, this led me to believe that light weight oil sloshing around in the tub might cause problems too. I could have been sniffing too much solvent.
Stuart
Nope Stu, you could have sniffed a little more and still nailed it. The thicker the viscosity the less chance of sloshing from G loads from accelerating, braking, turning and engine vibration simply make sence.
Even though all that is true about the recomendations for using a special #50 oil, every one of the shops that I worked in and hung around simply used the most readily avalable heavy earl!
That was back when oil bath air cleaners were common place.
Denny G
Denny G
Sandwich, IL
Did you really say "G loads from accelerating" when referring to the AD trucks? In the days before concrete and asphalt, that oil would be thickened in just a few miles, LOL.
I was just wondering, I convert everything to paper elements anyway, except tractors. Some of those are almost impossible to fit anything other than the oil-bath to.
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
