9 members (Phak1, klhansen, 3800GUY, Still At It, Gdads51, Bill Hanlon, 53&Me, 2 invisible), 90 guests, and 1 robot.
Topics128,137
Posts1,056,437
Members48,441
#796333 11/09/2011 3:41 AM
I just started a restoration project and the tag says that it is suppose to have a 230 6 cyl in it, but it has a 292 6 cyl. My question is, is this a huge deal? Should I stick with what I have, or should I seek out a 230 to put back into it?
Restoration is new to me, so I would like some advice! Thanks
Scott
Most people would jump at the chance to have a 292, and make a boat anchor out of their 230. Unless you're trying for a concours restoration to win car shows with, stick with the bigger engine. 230's were also notorious for getting cracks in the block between the valve lifter bores, which sometime let coolant leak into the oil. The motor mounts would have to be modified to install a 292, as the 230's and 250's had the front mounts directly across from each other, and the passenger's side mount is offset toward the front on a 292.
If I had the choice between a 292 that I already have or finding a 230 I'd keep the 292. More cubes, more power.
I love my '66 292................
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
My 230's been running for 49 years w/ no major mechanical issues or rebuilds.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
Thanks for the input! I was leaning towards keeping it, power, torque, and amazingly it is running incredibly for sitting for 5 years!
k10 Offline
The 292 is probably the ultimate early GM inline 6 in terms of performance. (a 302 GMC is perhaps more desireable, but the 292 is better engineered) It has 7 main bearings and represents the pinnacle of GM 6 cylinder engineering until the 4.2 Vortec 6 came out in the Envoy/Trailblazers. If a 292 was available for my 230 powered truck, I'd dump the 230 in a heartbeat for that 292. Leo Santucci has a great book on building this series of inlines. You really ought to pick it up and then you'll realize that you lucked out in getting the 292 already setup in your truck.
k10 #798906 11/18/2011 6:32 AM
There's a reason the 292 was around for decades. It's near bulletproof. Lots of parts availability and later versions had electronic ignition (starting in '75 I think?) which is an easy swap.
Tradin' up dimes for nickels...
My \'65 Chevy C-20
mugsy #799064 11/19/2011 12:36 AM
Lots & lots of pulling power
Dado #799095 11/19/2011 2:54 AM
I agree the 292 is the power maker and Leo's book is a must have for any of these inlines. But you could also just swap cranks for a 250 and pick up 20 cubes that way. A cousin just built a 292 for his mid 60s pick up and it will set you back in the seat.
1946 1/2-Ton Chevy
If you already have the 292 in your truck, I'd definitely stick with that. Most people don't know the difference between a 292 and a 194/230/250 anyway...
I have a 292 in my '63 Chevy II. Here are some pics:
292 in a '63 Chevy II
