3 members (Cosmo, Wayne67vert, Bills Auto Works), 60 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#794484 11/02/2011 4:09 AM
Take a look at the progress we are making on the '66 Chevy K20 at the shop:
Photo Slideshow of '66 Chevy K20
Nice work........
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Going to be a very nice truck
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
Thanks guys. I really like the factory Dark Blue/Off-White color combination. We are shooting epoxy primer & DuPont BC/CC, so it will be a bit nicer and a bit more shiny, than the original paint, but I think it will look very good.
Looks like fun and very nice work.
Sure looks great!
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
Tony,who refurbishes your shocks ? I saw them in the paint stage when I visited and you was not there.Your shop technician showed me your progress.Looks better than factory !!
Tim
1951 3100 Chevrolet
We did the shocks...protection, media-blast bodies, prime, wet-sand & top-coat. I used the factory-correct OEM GM shock paint. I had it mixed in a rattle-can at True over on Merriam Lane. They will mix any color and put it in a rattle-can for around $25.00, which is not bad, if you need a special color.
Thanks for the kind words...Super Dave said you stopped by on Friday. Sorry I missed you. Maybe you can come by again soon.
Beautiful workmanship on those rockers Tony. I sure wish I had lived close enough to have you do mine. A “highly recommended” local shop did mine several years ago and did so much damage to the truck I almost got rid of it.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
nice color combo I think I know what its going to look like
1965 Chevy Shortbed Fleetside
4 Wheel Drive K1445
More pix in Photobucket
Indeed, Curt, indeed!
I still have those shocks on my truck...are they the original? Ill be swappping them out in a few weeks and was just going to trash them
The spiral-body shocks were the factory-correct shocks for the '60-'66 Chevy light-duty trucks. I assume there were other options available, that were era-correct, but this is what is indicated in the data books.
We did not rebuild them, simply comestically refurbished them. On a 3/4 ton 4x4, the shocks aren't doing much, due to the stiffness of the leaf-pack. In any case, we felt it was a nice touch.
There is a business, that will rebuild your factory cores, but it is several hundred dollars...over $650.00, as I recall. We opted for the middle-of-the-road approach.
Thanks for looking and the kind words.
Making some more progress on the '66 K10. Take a look:
Progress photos
Tony,
Thanks for posting up the links to this build. Question for ya: Who have you found makes the best patch panels and who do you buy them from?
Hey John. Thanks for the kind words. Since we are in Kansas City, we commonly use LMC or Classic Parts. I have found the quality, fit & finish of the aftermarket patch panels, to be very inconsistent and it is a function of whatever is on the vendor's shelf. I have found that a part, that I find to be of high quality, this time, may not be the same quality, the next time I purchase the same part from the same supplier. Once the shelf-stock runs out, it is replenished with new inventory, which is not alway equivalent, to the prior stock.
In closing, a good sheet metal mechanic, can make a silk purse from a sow's ear, so I believe the key is, to some extent, the skill-set of the person doing the welding & top-dressing of the repairs.
Love it!
Nice job really coming together
4 Wheel Drive K1445
I
I Offline
Beautiful truck and nice attention to detail!
Dan
Walter's 65 Shop Truck
1965 Chevy 1/2-Ton
More pix on Photobucket
Well I have to say you guy's sure do good work. The K20 looks great. As I was looking through all the photos I noticed that you put some kind of material between the wheel wells and the bed side. I am in the process of putting my wheel wells in and would like to know what you used.Here is a link to some photos of my project. http://s1209.photobucket.com/albums/cc400/shortwide63/ and any info would be greatly appreciated.
1963 Chevy Shortbed
30 years in the works
In the DITY Gallery
Yes sir, that is definetly 1 good looking truck
Thanks for all the kind words. It will be on display at the World of Wheels show, in Kansas City, MO at the Bartle Hall Convention Center, February 10th-12th. If you are in the area, drop in for the show.
short63, we use 3M Windshield Gasket material or Bead Caulk. I like the windshield gasket material because it comes in a roll and you can put down what you need and cut to length. The factory assembly manual shows a gasket material, but I not sure what was actually used. We have had good luck with this material & application method.
Thanks for the info, I would assume that I can get the gsk. material from an auto supply shop. Hey just a note I used to live in Topeka and I sure wish I knew about you place back then and this site. Would have helped get some onfo I needed back then.
1963 Chevy Shortbed
In the DITY Gallery
Strip caulking comes in a box with several layers of strips, divided by layers of wax paper, to keep them from sticking together. Auto paint supply stores have it, if you FLAPS doesn't.
Sweet!
That looks fantastic!
59 Catalina
66 K20 Longbed
67 Camaro
2 69 Camaros
91 Mustang GT
99 Acura RL
00 Tundra 4x
08 Tundra 4d 3/4 LB 4x
Tony, very nice job. Simply put, I like the attention to details. Just can't find one any better!!
I heard it won "Best Restoration".
One beautiful truck,I'm sure the owner is going to love it.
Tim
1951 3100 Chevrolet
Thanks for the compliments, everyone. She showed well and we got a lot of positive comments and a few "head-stratchers, thinking it must be a NAPCO conversion".
Glad to you and your brother made it to the show, Tim. It was also good to see Charlie, KK, Ron, Rann, Super Dave and Mega Mike at the show!
You got me on Mega Mike,is that Oltrucks ?
Tim
1951 3100 Chevrolet
Indeed, he is...Mega Mike = Oltrucks!
What a great job!
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Thanks johntsmith.
JC Offline
An absolutely beautiful, inspiring truck! I can only hope that my 66 K20 will be 1/2 that nice someday.
JC in KC
"The future will be better tomorrow." Dan Quayle
1965 Chevy C10 Long Fleetside
Hey Jon C. Thanks to you & Sam and the others for help with the move on Saturday. Now, if I can avoid pulling my hair out, since the shop is in utter disarray, everything will be dandy.
P.S. - Thanks for the compliments on the blue K20!
