| | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78742 06/13/2007 3:39 AM | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | I have a inline 6 cylinder in a 1962 C10. The casting number is 3836848. And another number code F0123J.
I am trying to decode this so I know if this is a 235/261/292 (or even a later 230 or 250). I assume it is a 235, but not for sure.
Can anyone help me?
I went over to the INLINERS website, but was unable to find any match - if it was there I missed it. | | |
#78743 06/13/2007 4:04 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It looks like F= Flint 01= January 23= the 23rd and J= 235ci from 1962. Hope that's right, Scott | | |
#78744 06/13/2007 4:07 AM | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | Where and how did you decode this? Is there a reference chart somewhere?
I found my casting number on hemmings website that indicates 3836848 is a 235 from 1956 car. So I'm not sure if this engine is original to the 1962 pickup. | | |
#78745 06/13/2007 7:21 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The casting number you are listing is for a '58-'62 235 head. You need the number off the block behind the starter to really know what you have, since 235 heads can be put on 261's.
#78746 06/13/2007 10:58 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | colettesbro...you mention a 235, 261, or 292. Then asked if it is possible a 230 or 250 or one of the later engines.
A 292 is one of the later family of engines and has no relationship to a 235 or 261. Just wanted to clear that up for you. | | |
#78747 06/13/2007 1:02 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | if it is org it will be a 235,,,261 were not offered in a pickup and a 292 was later than 62..doc | | |
#78748 06/13/2007 3:42 PM | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Brian, My source is the "Cars and Parts Truck ID Numbers 47-72", Scott | | |
#78749 06/13/2007 4:41 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The head is for a 56-62 235 | | |
#78750 06/13/2007 9:53 PM | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | | | |
