4 members (cmayna, EddieD, 2 invisible),
47
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I am having a problem engaging 1st and reverse on a Muncie rock crusher. I believe you stick a philips screwdriver in a hole in the shift linkage, this aligns the shifter and you adjust the arms to fit? any advice?
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | The actual rig pin is a piece of 1/4" drill rod, but a #2 Phillips screwdriver is a pretty good substitute. It aligns all the shift levers in the neutral position. Then, make sure the trans shifters are all in the neutral detent, and adjust the shift rods to drop into the holes easily. Jerry
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Ran into a little problem and will have to redue the job this morning. Too embarassed to tell. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | C'mon now fess up. A little ridicule is good for the sole.  | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Taint fessing up other than to say I only have R-1st and 4th working Kinda a big jump without 2nd and 3rd. Tomorrow is another day. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Progress report. Well today I got 3rd back Tomorrow I will go for 2nd. Oh wait, I have a show I will have to slink into. | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Are you running the muncie off a floor shifter or the coloumn. Im still trying to work out the fine details, but im putting a 427 in my 63 in the spring and a muncie m22. I plan to use the coloumn shift for 1-4 and install a gate shifter for reverse on the floor. | | |
