0 members (),
123
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 25 New Guy | | New Guy Joined: Sep 2011 Posts: 25 | I have a 1941 Chevy loadmaster. I swapped the 41 235 for a 54 235. The only thing I'm having truble with is finding a gas pedle with the rod because the 41 rod is longer then the 54. Anyone know how I can find one or can I modify the rod ?? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | cut it and weld it. either take some out or put some in, It's unclear to me which you need to do. | | | | | Joined: Sep 2011 Posts: 25 New Guy | | New Guy Joined: Sep 2011 Posts: 25 | this is a picture of the motor. youll see the rod coming out of the fire wall its black with red paint on it, and youll see the part on the motor that comes out for the rod to atach to to complet the linkage to the carb. can I modify this piece? http://s1139.photobucket.com/albums/n542/1941chevyloadmaster/ | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Do you have the bell-crank that goes on the post in the block? The throttle rod from the pedal attached to one hole/arm in that bell-crank and a rod from the carburetor attaches to another hole/arm on the bell-crank.
| | | | | Joined: Sep 2011 Posts: 25 New Guy | | New Guy Joined: Sep 2011 Posts: 25 | Yes I saved those peaces from the 41 block when I did the swap. | | | | | Joined: Sep 2011 Posts: 25 New Guy | | New Guy Joined: Sep 2011 Posts: 25 | From what it looks like just cut the rod hook it up the weld it back togeather huh? | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Here is an adjustable linkage with a swivel head from The Truck Shop. Page 84, bottom right corner. May still be too short(?) I have seen similar rods from other suppliers, possibly longer than the ones from the Truck Shop. FWIW, my '54 rod is too short when I use a carb insulator plus 1/16" gaskets on top and bottom. I run with insulator only -- no gaskets.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | That's it I doubled it back on itself a bit about and inch or so and then welded on both sides. I would suggest that since it is only 1/4" in dia it holds up that way. It also allows you to adjust it correctly before you weld it all up.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Here is a suggestion. Cut an additional 3" or 4" out and install a turnbuckle. Just cut the hooks or eyes off and weld them directly to the ends of your cut rod. You can lay them in a piece of angle iron to keep them straight while you tack weld them and then weld them good all the way round. Then you will have some adjustment and can use all the gaskets or spacer you need on your carb. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you have all the parts and all you need to do is to shorten the pedal rod, Vern's suggestion is excellent, especially since the turn-buckle allows adjustment of pedal height.
| | | | | Joined: Sep 2011 Posts: 25 New Guy | | New Guy Joined: Sep 2011 Posts: 25 | Okay I will give it a try. I thank you all for the help. Can't wait to get it all put together. Thanks again | | |
