4 members (mick53, 1955 1 Series, Leo, stlcardinalsguy), 77 guests, and 4 robots.
Topics128,180
Posts1,057,156
Members48,464
1 Offline
I have a 1941 Chevy loadmaster. I swapped the 41 235 for a 54 235. The only thing I'm having truble with is finding a gas pedle with the rod because the 41 rod is longer then the 54. Anyone know how I can find one or can I modify the rod ??
cut it and weld it. either take some out or put some in, It's unclear to me which you need to do.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
1 Offline
this is a picture of the motor. youll see the rod coming out of the fire wall its black with red paint on it, and youll see the part on the motor that comes out for the rod to atach to to complet the linkage to the carb. can I modify this piece?
http://s1139.photobucket.com/albums/n542/1941chevyloadmaster/
Do you have the bell-crank that goes on the post in the block? The throttle rod from the pedal attached to one hole/arm in that bell-crank and a rod from the carburetor attaches to another hole/arm on the bell-crank.
Here is a picture of mine I have a 235 (54) in a 1950 3600 you can see the bellcrank and linkage.
http://community.webshots.com/photo/2087754340102454676JrahwI
1 Offline
Yes I saved those peaces from the 41 block when I did the swap.
1 Offline
From what it looks like just cut the rod hook it up the weld it back togeather huh?
Here is an adjustable linkage with a swivel head from The Truck Shop. Page 84, bottom right corner. May still be too short(?) I have seen similar rods from other suppliers, possibly longer than the ones from the Truck Shop.
FWIW, my '54 rod is too short when I use a carb insulator plus 1/16" gaskets on top and bottom. I run with insulator only -- no gaskets.
- Lonnie
My '54 3104
That's it I doubled it back on itself a bit about and inch or so and then welded on both sides. I would suggest that since it is only 1/4" in dia it holds up that way. It also allows you to adjust it correctly before you weld it all up.
Here is a suggestion. Cut an additional 3" or 4" out and install a turnbuckle. Just cut the hooks or eyes off and weld them directly to the ends of your cut rod. You can lay them in a piece of angle iron to keep them straight while you tack weld them and then weld them good all the way round. Then you will have some adjustment and can use all the gaskets or spacer you need on your carb.
1953 Chevrolet 3600
If you have all the parts and all you need to do is to shorten the pedal rod, Vern's suggestion is excellent, especially since the turn-buckle allows adjustment of pedal height.
1 Offline
Okay I will give it a try.
I thank you all for the help. Can't wait to get it all put together. Thanks again
