1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#78073 05/22/2007 12:48 PM
V
V Offline
I have a 350 that is hard to start when hot. I tried adjusting timing to no avail, new rebuilt starter. Can anyone help? Thanks...Virg
#78074 05/22/2007 12:59 PM
HMMM usually a hard start when hot is Timin , could your starter be gettin too much exhaust heat ?..maybe a sheild or wrap is in order ...just throwin things out at ya
1952 Chevy Shortbed
Photos in Photobucket
#78075 05/22/2007 1:49 PM
Virg, I had the same problem. trie everything, new starters,new battery, new ign.switch.new cables. till some one here at the bolt put me on to a heavy duty starter. Mine said he was for a 1975 chev G 30 van v8/350 Bought it at murrays for $52. returned the old one that I bought from them for 36. their bosch # 25374. murray # 1047204 It spins it so fast I am astounded. Trust me this is the answer.
#78076 05/22/2007 4:46 PM
i used to have the same problem it was my exhaust makeing it too hot.
#78077 05/25/2007 4:48 PM
Virg,
You could have a couple of different problems. Does it turn over and not start or does it not turn over when it is hot? I agree with the above about the starter but if it turns over fine but fails to start you may have a fuel problem. Some carburetors like Edelbrock tend to flood over when hot. When it finally starts does it run OK or does it run rough for a few seconds? If it runs rough it is an indication of flooding.
Fred
#78078 05/25/2007 5:19 PM
I gotta go with Gazim on this one.
Heavy Duty Starter.
Though, a heat shield won't hurt anything (starter-wise).
#78079 05/26/2007 3:04 PM
Virg, I tried the heat shield among others, didn't help, I did re install it with the new heavy duty starter tho,
#78080 05/26/2007 5:05 PM
Heat shield and heavy duty starter have worked well for me on a 400 small block with 10 1/2 to 1 compression ratio. It cranks over good and fires right up.
#78081 05/27/2007 4:59 PM
V
V Offline
Going to try a hi tourqe starter , hope it works. One guy told me it was his flywheel...?? Thanks for the replys will post results...Virg
#78082 05/27/2007 6:00 PM
Is your engine cranking too long before firing, or cranking too slowly to fire? These would be two seperate issues. one starter,battery or ground related and the other not.
A little more info on the "hard start" would definately help resolve your issue grin
#78083 05/27/2007 6:41 PM
V
V Offline
When it gets to operating temp. it just barely turns over. It has to cool down before it will start agin. I have tried jumping it but still wont start. I think I have taken care of the ground. I might install the new starter tomorrow. Thanks Virg
#78084 05/28/2007 6:16 AM
Sonds like the a new starter might do the job. If not then you will have to look at getting a heat shield of some kind. If you still have problems I would be looking at your cables and connections.
Both positive and negative.
Good luck!! wink
#78085 05/28/2007 6:19 AM
#78086 05/30/2007 3:45 AM
Along with the heat shield and HD starter which is a must, I would also install the heaviest battery and ground cables I could find. They will carry the amperage MUCH better yahn stock cables. Been there, done that. It works for me. That should solve your problems. I wish you well. Henry
