0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78073 05/22/2007 12:48 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | I have a 350 that is hard to start when hot. I tried adjusting timing to no avail, new rebuilt starter. Can anyone help? Thanks...Virg | | |
#78074 05/22/2007 12:59 PM | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | HMMM usually a hard start when hot is Timin , could your starter be gettin too much exhaust heat ?..maybe a sheild or wrap is in order ...just throwin things out at ya | | |
#78075 05/22/2007 1:49 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Virg, I had the same problem. trie everything, new starters,new battery, new ign.switch.new cables. till some one here at the bolt put me on to a heavy duty starter. Mine said he was for a 1975 chev G 30 van v8/350 Bought it at murrays for $52. returned the old one that I bought from them for 36. their bosch # 25374. murray # 1047204 It spins it so fast I am astounded. Trust me this is the answer. | | |
#78076 05/22/2007 4:46 PM | Joined: Jan 2006 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 74 | i used to have the same problem it was my exhaust makeing it too hot. | | |
#78077 05/25/2007 4:48 PM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Virg, You could have a couple of different problems. Does it turn over and not start or does it not turn over when it is hot? I agree with the above about the starter but if it turns over fine but fails to start you may have a fuel problem. Some carburetors like Edelbrock tend to flood over when hot. When it finally starts does it run OK or does it run rough for a few seconds? If it runs rough it is an indication of flooding. Fred
#78078 05/25/2007 5:19 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I gotta go with Gazim on this one.
Heavy Duty Starter.
Though, a heat shield won't hurt anything (starter-wise). | | |
#78079 05/26/2007 3:04 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Virg, I tried the heat shield among others, didn't help, I did re install it with the new heavy duty starter tho, | | |
#78080 05/26/2007 5:05 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Heat shield and heavy duty starter have worked well for me on a 400 small block with 10 1/2 to 1 compression ratio. It cranks over good and fires right up. | | |
#78081 05/27/2007 4:59 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | Going to try a hi tourqe starter , hope it works. One guy told me it was his flywheel...?? Thanks for the replys will post results...Virg | | |
#78082 05/27/2007 6:00 PM | Joined: Apr 2007 Posts: 20 Member | | Member Joined: Apr 2007 Posts: 20 | Is your engine cranking too long before firing, or cranking too slowly to fire? These would be two seperate issues. one starter,battery or ground related and the other not. A little more info on the "hard start" would definately help resolve your issue  | | |
#78083 05/27/2007 6:41 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | When it gets to operating temp. it just barely turns over. It has to cool down before it will start agin. I have tried jumping it but still wont start. I think I have taken care of the ground. I might install the new starter tomorrow. Thanks Virg | | |
#78084 05/28/2007 6:16 AM | Joined: Apr 2007 Posts: 20 Member | | Member Joined: Apr 2007 Posts: 20 | Sonds like the a new starter might do the job. If not then you will have to look at getting a heat shield of some kind. If you still have problems I would be looking at your cables and connections. Both positive and negative. Good luck!!  | | |
#78085 05/28/2007 6:19 AM | Joined: Apr 2007 Posts: 20 Member | | Member Joined: Apr 2007 Posts: 20 | | | |
#78086 05/30/2007 3:45 AM | Joined: Jan 2007 Posts: 202 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 202 | Along with the heat shield and HD starter which is a must, I would also install the heaviest battery and ground cables I could find. They will carry the amperage MUCH better yahn stock cables. Been there, done that. It works for me. That should solve your problems. I wish you well. Henry | | |
