0 members (),
123
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | How about it, guys? Anyone done this? Can I just swap to the 1/2 ton complete cross member? What fits what? | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I'm sure someone will correct me if I'm wrong, but you should be able to simply bolt in the 1/2 ton ifs. I'm not an expert on the 3/4 ton front end, but if I recall they are essentually the same as the 1/2 ton. What makes you want to swap?
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I'm going to agree with Rob, I think they all just bolt in. You might have to drill a few extra holes for the 1/2 ton to bolt in but I think that's about it. Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | ....but why would you want to? Scott | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | DISC brakes and 5 lug wheels Scott and MO! I have lots of 7" and 8" X 15 5 bolt wheels. Eight lug 16.5 X 6.5s really limit your possibilities for tires. I also found out that I can swap just the lower "A" arms and outer tie rod ends and get to the same place. Also, a '73 -'88 3/4ton cross member with discs will bolt in, too. I guess it depends on what I can find, what I'll do. I'd like to be able to use the stuff I have. Many thanks to everyone for their input. | | |
