0 members (),
90
Mod | | | Forums66 Topics128,139 Posts1,056,447 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | After reading Bruce's post about the best chamois I thought I'd ask if anyone has ever detailed their car or truck using the clay bars. I did some reading on them not long ago and its stated that the pro's at the BIG FANCY car shows use the clay bars to really spruce them up.
So, if any of you have ever done this would you please give us your experience and tips on the brands and the how to's. Is it that tough to use it. Thanks | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Hi Alvin.....I have used Clay bars on both my '40 and BMW. Its pretty amazing the amount of crud that is left on your paint after washing ! The clay takes it off really well. If you run your hand before & after, paint is much smoother. After you " clay " you need to rewax the vehicle. Pretty easy to use / just keep the surface wet | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A guy I know from Inliners used it on his car. At the time he told me about it he hadn't completed doing the entire car. You could see and feel the difference. Pretty impressive. None of mine have paint good enough to use it on though. | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | It may vary depending on the quality of your paint job. I have used clay bars and see no difference in the finished job. The clay bar is picking up some stuff because it will get some discoloration and has to be folded into itself to keep it clean. On my vehicles I can see absolutely no difference between areas I used a clay bar on and those I didn't. I quit using them. When I did use them it was on paint that did not need compounding, just polish and wax.
Chuck | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bruce, when you say wet you mean keep the hose running on it or just dip it in the pail and rub...dip in pail and rub... I know it has instructions on the clay bars but first hand experience trumps instructions!!! | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | There are specialized solutions sold by the same folks that sell the clay bars. You should also be able to find some at any FLAPS that sell clay bars. I think they would try to stick with just water. You want them to glide when you are using it.
Chuck | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Folks I know with high end cars swear by the clay bars
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Folks I know with high end cars swear by the clay bars That's cause they don't do the rubbing, they just write the check.  | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Alvin......I just use a spray bottle with plain water. Keep the area you are working on nice and wet. As Hookalatch mentioned, you just keep folding the clay over on itself as it picks up the grime. | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | I detail vehicles as a side business and have for over 40 years. If you want to wax or polish (even with a buffer) and you want to make it easy on yourself, clay first--it's only been available outside of the commercial autobody stores for the past few years. Don't bother using the detailer that sometimes comes with the kit, just wash the vehicle and leave it wet--even soapy is OK, keep it wet and go over the body panels and even the glass with the clay. It will take off tar (tar remover works better, though) and overspray. Then spray off the vehicle, dry, and wax. BTW, if you ever get overspray on the plastic lenses of your glasses, it is about the only safe thing to use on them--and it works. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | THANK YOU guys. Just what I wanted to know. This will make a nice "winter project". | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | VERY interesting thread. We sold clay bars where I used to work, but I never talked to anyone who used them. Good info!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Hey Alvin, I used mine on my windshield too. It never squeegeed so well when I have the wipers on. Better than Rain Off. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks Paul. I haven't had the time to try it yet but it is on my "to do" list for the 37. After all these years it DESERVES a good quality sprucing up. Again, thanks guys for your input. | | | | | Joined: May 2010 Posts: 85 New Guy | | New Guy Joined: May 2010 Posts: 85 | I have been detailing for over 12 years....I read everyone's post...here are my quick tips: my preferred "over the counter" clay bars are 'clay magic' or 'mothers' Use soap and water for the lubricant. You do not need to buy specific lubricant for the clay bar....it's a sales scheme. Wash the car, then clay it, wash it again....then dry it and wax it.
The purpose of the clay is to remove surface contaminants and airborn "fallout" You will know when a section is done cause it will feel very smooth.
Clay does not remove scratches. Do not use circular motions. Go "with the airflow" (that's my technique)
If anyone wants to talk further....feel free to Message me.
If you are an online shopper, check out autogeek.com (I have no affiliation to them)
Do something! Even if it's wrong!
