4 members (Gdads51, 1955 1 Series, Bill Hanlon, 1 invisible), 336 guests, and 6 robots.
Topics128,162
Posts1,057,068
Members48,463
Page 1 of 8 1 2 3 4 5 6 7 8
#768999 08/06/2011 1:11 PM
I have given my truck a project designation XJ-PU V12, XJ because all the running gear is from a 1986 Jaguar XJS as well as the suspension, PU pickup and V12 for that fantastic Jaguar racing designed engine.
What a lot of people do not know is Jaguar had a deal with GM and used a lot of there parts in the Jaguar models, my V12 is married to a Turbo 400 trans for example which to me is kinda bringing things back home in my mind, wish me luck
1940 Chevrolet 3/4-Ton
"Project XJ-PU-V12"
More pix on Flickr
In business, words are words, explanations are explanations, promises are promises, but only performance is the true reality.
Sounds like it could be pretty cool, but what truck is this going into?
Here's the link to the post in the Welcome Center. It looks like a way-cool cool project. grin
Husker #769221 08/07/2011 3:32 AM
If you can pull this off that should be a great running,driving truck,talk about a quart in a pint pot though.
It should sound really nice too.
Good luck with the 'Coventry Cat-bolt'! thumbs_up
More pix on Flickr.
I looked around for a truck for about 12 months I had this doner car XJS from a XJS-C that I restored I kept the suspension and drive train with a vision of placing this into a old pickup truck one day.
I viewed about 6 trucks then I found this one a 1940 3/4 ton pickup very little rust no engine or trans or back axle for that fact it was a perfect candidate for the V12 which brings me up to date.
I have my suspension figured out just need to decided on engine position to move my project on a level.
"Project XJ-PU-V12"
More pix on Flickr
The Sports Car Club of America racing team I worked with back in college (mid-1960's) had a 55 1st. series pickup with a Ferrari V-12 in it. That one was a real sleeper! It was mated up to a Colotti 5-speed transmission and a Jag XK-140 rear axle. Of course, it ran like a Ferrari, and handled like a pickup! A straight axle and 4-wheel drum brakes didn't help, either! Not a good combination!
It will be interesting to see how this truck handles with the Jaguar independent suspension I am thinking it will be a bit light a the back end might be difficult to get the traction down
"Project XJ-PU-V12"
More pix on Flickr
You will need alot of radiator, those V-12's cannot get hot, that's why there's a Chevy small block conversion kit that's so popular to revamp the 12 cylinder Jag's,
just a thought,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Can't see it being any worse than using a live axle set-up,I imagine it should handle even better!
Are you retaining the cage as well,the Jag IRS is a fairly hefty piece of kit.
Pick-ups by their design will always be prone to less traction,unless you load the sucker!
More pix on Flickr.
Would love to see it. Go threw the wiring real good. The main issues they had with the V12 jag was the electrical. And the rear suspension had soft rubber bushings. They make replacment aluminum bushings to fix the issue. Good luck. Would love to see it. That has always been my favoret jag.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
The radiator choice will be critical electric fan or fans is a must I will be keeping the jag rear cage bolted direct to the frame same with the front suspension, one thing I am looking forward to is the wiring the XJS was a complex car and pre can-bus so there is a million miles of wiring in the vehicle this caused a few issues to say the least, I will be simplifying wiring and vacuum systems still a lot to figure out but that keeps it interesting.
"Project XJ-PU-V12"
More pix on Flickr
Just started to get a handle on this flickr photo site here goes,
http://www.flickr.com/photos/moff1959/sets/72157627429556918/
"Project XJ-PU-V12"
More pix on Flickr
moff1959 #771624 08/15/2011 12:17 AM
Flickr link works for me moff....Looks like you're making good headway with the truck.
More pix on Flickr.
Looks like it will be one fun little pick up. Pictures look good.
My YouTube:
I overhauled the Dana differential yesterday looking at the internals its heavy duty and bullet proof made in the USA, cleaned lubricated and new seals its ready to be assembled to make up the Jaguar IRS (independent rear suspension). Inboard rear brakes next I have decided to leave out the rear cage and make a cross member for the diff to mount to you get to see all that engineering Jaguar techs developed and it just gives it a better look.
posted a few extra pics of the differential
"Project XJ-PU-V12"
More pix on Flickr
Thanks for the great photos. That looks to be a really interesting project.
BTW, the Dana manufactured differential unit that you have is quite rare on a Jaguar, most had the UK manufactured Salisbury diff which had 10 splines on the pinion, rather than your 26 spline setup.
Best of luck with the project.
Thanks Stuart, hey nice job on the truck by the way!
cheers Paul
"Project XJ-PU-V12"
More pix on Flickr
Hey Paul(Moff) looks like your truck's caught the attention of 'us' Brits! wink
BTW. I hope the quake hasn't caused too much chaos where you are....
More pix on Flickr.
Hey john I am a Manchester lad originally, I was working under an XK140 when it nearly rocked off the lift the light fittings were swaying back and forth so I legged it outside the lamp post were swinging around strange feeling but all is well here no major injuries or damage
"Project XJ-PU-V12"
More pix on Flickr
moff1959 #774762 08/25/2011 12:44 AM
I assume judging by your reply you're a Jaguar technician then,that explains a lot!
Sounds scary!
My wife's best friend stays in Newport News,she's a Scots lass and had never experienced a quake,so between that and tornado warnings,she's a nervous wreck!
There was a tornado touched down near Va. Beach when we were there last year.
I've never seen thunderstorms and rain like it.....spectacular!
The problem is she was told to listen for a sound like a freight train coming,problem is she stays about a 1/4 mile from the train tracks!
More pix on Flickr.
I was at my friend Lou's on Saturday. He's build a tow truck with an old MG chassis and a Jag V12. It will be for towing vintage race cars.
Did I mention it was a 1956 XK140
check out www.classiccarcenter.net this is where I work
"Project XJ-PU-V12"
More pix on Flickr
Would love to see some pictures is he on the internet?
"Project XJ-PU-V12"
More pix on Flickr
"Project XJ-PU-V12"
More pix on Flickr
Front axle is in and looks good, need some heavy channel for the rear axle fixing
"Project XJ-PU-V12"
More pix on Flickr
Wow. That is looking good
My YouTube:
Wow, That is a cool truck
Ken
1946 Chevrolet 2-Ton
More pix of the '46 on Photobucket
1954 Chev 1/2-ton
3 Farmalls
4 John Deeres
1 Oliver
1955 DeSoto Fireflite
I'm pullin for ya. We're all in this together -- Red Green
Don'tcha just love it?
gazim #815259 01/10/2012 11:44 PM
Just posted more pictures in the photo link
"Project XJ-PU-V12"
More pix on Flickr
Just a very nice set up that will corner so well. When completed you may need some track time up at Summit Point just for fun. smile
Drew
DrewP #815364 01/11/2012 5:07 AM
This truck is looking so sweet! Awesome job!
Gmans 46 #825635 02/12/2012 11:56 PM
I have some later pictures loaded front and rear suspension done engine and trans mounted just ordered a custom built radiator and cut the cab to let the V12 in time for some body work
"Project XJ-PU-V12"
More pix on Flickr
It's coming along well, looks really good.
Looking great as always Paul,I'm enjoying seeing an earlier truck coming together,especially with it's Coventry connections. wink
More pix on Flickr.
DrewP #829075 02/23/2012 7:05 PM
WOW. Dose the GM trans bolt right up with no adapter?
Nice Job Its coming along great.
My YouTube:
AFAIK The V12 Jags had a TH400 trans from the factory.
I'm sure Paul could confirm this.
More pix on Flickr.
Thats right standard kit for Jaguar TH400 has a different case but all the internals are similar, Jaguar used a few GM parts ignition amp for example, with a little bit of thought you can get most things to fit. I just fitted my radiator of choice and now I figured out I can bring the engine and trans forward 3" should have the electric fan this weekend to confirm my measurments. Fuel injectors are away being cleaned and tested so things are coming together, keep checking the album post new pics most weekends
cheers
Paul
"Project XJ-PU-V12"
More pix on Flickr
Thanks for the confirmation Paul,I don't want to get too far O/T but are you having problems with Flickr? I am......
Just curious.
More pix on Flickr.
No problems for me except I am reaching my 200 pic limit and will need to upgrade which means putting my hand in my pocket for some cash, being of Scottish decent you know how that hurts!
"Project XJ-PU-V12"
More pix on Flickr
Flickr's OK now,server issues apparently.
It's good to see you're true to your roots Paul.
Keeping up the short arms/deep pockets tradition! grin
Any progress on the truck?
More pix on Flickr.
