3 members (Hotrod Lincoln, dt235sd, klhansen), 111 guests, and 2 robots.
Topics128,127
Posts1,056,679
Members48,452
#688618 10/23/2010 4:56 PM
TGP
Offline
Just brought this solid old Jimmy home.
4-71 Detroit,5 Speed OD,3 Speed Aux.,2 Speed rear.
Always been inside and was last registered in 1974.
Fired it up and drove it home!
Truck Run's and Drives Great once the tires round out,lol
More than likely will remove the "Holmes" wrecker and make a tractor out of it.
Currently looking for a "back in the day" sleeper box for it.
50's,early 60's or older is what I have in mind.
Any help locating one would be Greatly Appreciated.
Thanks to John & Peggy for a great Site!!!
Picture here @ http://www.t137.com/cpg/albums/userpics/10010/Ed_s_GMC_side.jpg
My Album is here @ http://www.t137.com/cpg/index.php?cat=10010
Thanks All
Tom
TGP #688629 10/23/2010 6:08 PM
Welcome!! That is a COOL truck. Do you know the history? The front wheels look more modern with the larger diameter 10-stud circle.
Cool album of truck pictures too. wave
Professional Novice
TGP
Offline
Thanks Frank!
Your 50 is pretty "Sweet" Too.
The truck from what I understand was bought in the mid fifties as a tractor with a broken frame.
A new replacement frame was purchased in the proper wheelbase and the wrecker body was installed.
The front axle is original(will check that further),the rear I'm not sure, as it has a Eaton electric two speed.
Need to research that too.
The aluminum Budd's are very early tube style,probably late sixties, early seventy's.
TGP
TGP #690585 10/31/2010 1:15 AM
Nice looking truck... enjoyed it alot
TGP
Offline
Your 57 is a beautiful truck!!
With also a Great History.
We also have a 58 550 GMC.
Awesome old Iron for sure!
TGP
TGP #774604 08/24/2011 12:29 PM
Tom,
It may not be a Chevy or GMC, but all I can say about your '47 Power Wagon is, WOW! Great job!
R Online: Content
That wrecker looks cool just the way it is, but it's your truck. Good luck on your project. Also, I like that Power Wagon too!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
The 5 hole alum wheels were built starting in the early 50's and were used up till the late 60's when Alcoa brought out the 10 hand hole tube type wheel.
Moderated by  J Lucas
