Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Tronman, Stewart2, MickeyP, 2 invisible), 144 guests, and 4 robots.
Topics128,288
Posts1,058,581
Members48,492
#769664 08/08/2011 6:19 PM
Thought y'all might enjoy seeing and hearing one.
Here's the whole photo album
And here's the you tube video
I heard about it while ago at a truck show and made arrangements to buy it, then later took a road trip to fetch it. Got it running a few weeks ago, that video is literally the first attempt at starting it.
Now I'll finish cleaning it up, make some new exhaust pipes between manifolds and the turbo.
Then to figure out what to do with it...
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Sounds like you got a good one! I've got a 55.1 COE we could stick it in!!!!
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
It sounds better then the Detroit in my yard truck. We could trade.
24601
24601
Scott, in the video, it looks like he is getting ready to put it in the Jetta ... smile THAT would be different.
JM
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
I can't explain what that sound just did to me. Pure inspiration.
Thank you for posting, Grigg.
Jake
JM
Sparks would fly!...from the front end dragging!...haha
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
You gota love'em, I like to think of them as a big block chevy on diesel. I've got the sickness to. Got a pair of 271s. Like to start them up once in awhile, I also have a pair of 16V71s with twin turbos mounted on shids. The local scrap yard got in 5 of these and I was able to save 2 of them, have not fired them yet but I,m sure it will impress the neighbors.
That is one sweet sounding engine! Seen lots of supercharged 8v's but never a turbo. Now to find just the right chassis/home for that bad boy...hmmmm......
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
I doubt you've seen all that many 8V53 Detroits? They are reasonably rare to start with and usually found as marine engines. (Lots and lots of 8V71 and 92 engines though)
Have you checked the rotation? I was going to add to my wise remark that I might be afraid that my yard truck might run backwards. I'm sure it was a stationery engine or marine, and most marine Detroits run backwards.
Check the video, it runs correctly for a vehicle.
It was military surplus from a tank or armored personnel carrier sort of thing. After that best I can tell and from others that know the engine it was swapped into an L model ford truck, and then obviously removed.
Grigg
---All pictures---
Just a few minutes ago I ran across a 6v53 at a surplus/salvage yard with a turbo which is fairly uncommon too. It was a stationary. My old Blue Bird bus had a supercharged 6v53...you know...the one they call "the Screamer". Same engine as what was used on most of the "Brown Water Navy Swifts" on the Mekong & Saigon in pairs. Almost as dangerous as the twin .50's!
A close look at the pulley right before the puff of smoke does reveal the direction. I never thought of the military.
Hey Grigg keep your eye on the military surplus Detroit’s. Although in the civilian world the use of the two cycle diesels ended before the advent of electronic fuel control the military still uses them and I have seen many computer controlled 8V-92s. These computer controlled motors produce better power and consume less fuel.. Kind of a mix of old and new technology that only the government got. However I don’t know if the electronic fuel controls have been used anything else but the 8V-92
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Electronic 4-71 and all the larger 71's as well as all the 92's were available and in use by civilians prior to 2000. DDEC controls they're called.
A DDEC 6v53t was available for the military, I think its the only electronic Detroit we couldn't get, but I have seen two of them available surplus.
---All pictures---
Looks good and sounds good. I don't know a whole lot about them other than they are usually found as marine engines. Glad to see it turns the correct way.
Keep us posted.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
