| | | Forums66 Topics128,090 Posts1,056,018 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76516 04/20/2007 10:36 AM | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I installed a 454 w/TBI in place of a 350 w/carb. in my work truck recently and of course gas is now over $3.00 a gallon, I tow a 26'(8500lb)fifth wheel camper several times a year and the rear end has a 4.10 gear in it now. it's great for towing BUT for everyday driving it's killing me at the gas pump, Im thinking about changing the gear but I don't want to take away from it's towing capacity (much) I know it's not going to get great mileage with the big block but any helps... any ideas ?? "besides selling it" Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | |
#76518 04/20/2007 8:00 PM | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Grigg. Thanks for the links I thought about a gearvendors, Man... that would be awesome but it's pricey ($2500.00) have you or anyone ever used the ranger or saturn overdrive units ? I called a local shop and they recommended a 3.42 gear! That sounds crazy I think they were just "making the sell" I switched the 350 with the 454 because of lack of power and I think Id be right back to where I started from with the 3.42 gear "I should have put the Big block in the 51.. sold the 350.. and BOUGHT A DIESEL" LOL !!
Your 48 is going to be awesome !! Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | |
#76519 04/20/2007 9:04 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You didn,t say what trans. you are running but what about a L80 auto o-drive from a early 90,s truck. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#76520 04/20/2007 9:14 PM | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Sorry about that the trans is a 400T I looked into a 700R but I don't think it would handle the towing... but I'm not sure Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | |
#76521 04/21/2007 3:03 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Regardless of what you do, you're not going to get much better fuel economy. The money you spend on economy upgrades will never be paid for in savings at the pumps. Buy a beater light duty truck for daily driving and keep the tow rig a tow rig, Just my 2 cents worth | | |
#76522 04/21/2007 4:29 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | good point about not saving money. Assume the overdrive swap cost $1500, you get 12 mpg now, and with the overdrive you get 16, and fuel cost $3 a gallon. It's late, and my brain is not working quite right. But I figure it takes 60,000 miles of driving with the OD installed to pay for the fuel savings. Someone check me on this please.
I just assumed you had a manual, as all real trucks have manual transmissions. If you did then I think that the Ranger OD is probably the best buy. You could switch to a manual? If you did go with a manual you have overdrive transmission choices, like the expensive NV4500. Or with some work, and a flywheel, clutch and bellhousing from a big truck like a dump truck you could install a surplus cheap spicer 5 speed model 3053a from a deuce and a half with about .84 OD. Or as mentioned before an automatic with an OD, but I know next to nothing about automatics. I do know that all un-computerized Allison's are direct drive. It was not until they were computer controlled that they were offered with OD, and the newest ones in a Chevy truck have two overdrive gears, high is about .64.
Grigg | | |
#76523 04/21/2007 7:58 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | 'the trans is a 400T I looked into a 700R but I don't think it would handle the towing... but I'm not sure
If your TH400 is doing the job you have then I'm sure the 700R4 OD would do it equally well. I've done a lot of towing with mine w/o any problems whatsoever and 187K on it. | | |
#76524 04/22/2007 12:36 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have an '89 1-ton four-wheel-drive with a TBI 454 and a Turbo 400. I don't drive it much because the fuel economy is awful. Best I've ever done with a trailer behind it is 10. And that was rounding up.
The 700R4 or 4L60 are not heavy duty transmissions. I would not want to bet on them holding up with that trailer behind you. The 4L80 is tougher but expensive. Its the OD transmission based on the Turbo 400.
I keep thinking about a swap like this and since I don't use it much I would not save more than a few hundred a year if I could improve milleage by 50%. The economics don't add up. Since I have a more economical car I like to drive I just drive the truck less when gas goes up.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#76525 04/25/2007 10:07 AM | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Thanks everone I think your right Im going to leave it alone and keep it "a tow rig" I'll just have to get a economical car or truck for daily driving Thanks
Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | |
