8 members (66flea, Southerntruck, Otto Skorzeny, GMCJammer51, Phak1, TGP, DadsFirstPickup, Wayne67vert), 118 guests, and 2 robots.
Topics128,049
Posts1,055,682
#762604 07/15/2011 3:04 AM
My 37 Chevy truck has a Rochester Carb and it runs like crap. I would like to switch to the Carter W1 carb I have but the flange on the W1 is narrower. Is there a carter carb available that will fit the rochester flange
thanks
1937 Chevy 1/2-Ton Pickup x3
1940 Chevy 1/2-Ton Pickup
1940 Chevy 1 1/2-Ton COE
1941 Chevy 1/2-Ton Pickup
1941 Chevy 1 1/2-Ton COE
1941 Chevy 1/2-Ton Suburban
1946 Chevy 1 1/2-Ton COE
1971 Chevy 1/2-Ton Pickup
Are you saying it won't bolt up because the holes don't line up, or just the flange is a bit different? I thought (maybe incorrectly) Chevy used Carter W1, Rochester and Carter YF carbs, depending on model, year, etc. But, maybe the intakes are different?? Somebody will let us know, I'm sure!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
I don't know about your setup but on my 38 Master with the 216 I replaced the W1 with a Rochester B and the only difference was the angle on the vacuum line.
1951 1 Ton Completed
The bolt spacing on the rochester is wider. The engine might not be original. It is definatly splash oil, but it could be a 216 or a 235. Did they have different intake manifolds between the two engines.
1950 and later 235s have a wider bolt spacing than 216s.
My Blog
Is there a carter carb that will fit this wider bolt spacing?
Carburetion specialist
C Online: Content
The short answer is: YES
The long answer:
The size 2 (2 11/16 c-c mounting) was used on the 216, and early 235's.
The size 3 (2 15/16 c-c mounting) was used on 235's, 250's, 261's, and 292's. Just because a carburetor will bolt up does not mean it will work. The internal venturi size will vary, based on the displacement. Very first thing to do is determine EXACT engine size and year. Then you can look for a carburetor that will function well with the engine.
Jon.
The Carburetor Shop
The motor is a 1952 216 GM 3835794. The stud spacing is 2 15/16. Any ideas on locating a carter that will work.
It looks like someone has installed a later-model 235 mainfold on your 216. That's possible with a set of stepped-down alignment rings in the intake ports. You'll probably need to find a 216 intake, and then get the correct-size carb for a 216 engine. Even if you find a carb that fits the manifold, it's not likely to be calibrated to work with a 216.
Don't jump on me for this, but 19ci between a 216 and 235 isn't that big of a difference and any of the 235 era carbs should work reasonably well. I prefer the Carter YF over the Rochestor B. It's a great carb and easy to work with, but there were many variations of that same carb over a span of years.
Jeff
My 1953 Chevrolet
1947.1 Gallery
I have a 1937 W-1 and a matching intake. Will the intake bolt on to the 52 exhaust manifold?
Or what YF would be a fit on my 216 with 2 15/16 spacing?
thanks
