2 members (Bill Hanlon, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2003 Posts: 19 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 19 | My 37 Chevy truck has a Rochester Carb and it runs like crap. I would like to switch to the Carter W1 carb I have but the flange on the W1 is narrower. Is there a carter carb available that will fit the rochester flange
thanks 1937 Chevy 1/2-Ton Pickup x31940 Chevy 1/2-Ton Pickup1940 Chevy 1 1/2-Ton COE1941 Chevy 1/2-Ton Pickup1941 Chevy 1 1/2-Ton COE1941 Chevy 1/2-Ton Suburban1946 Chevy 1 1/2-Ton COE1971 Chevy 1/2-Ton PickupIn the Stovebolt Gallery | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Are you saying it won't bolt up because the holes don't line up, or just the flange is a bit different? I thought (maybe incorrectly) Chevy used Carter W1, Rochester and Carter YF carbs, depending on model, year, etc. But, maybe the intakes are different?? Somebody will let us know, I'm sure!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know about your setup but on my 38 Master with the 216 I replaced the W1 with a Rochester B and the only difference was the angle on the vacuum line. | | | | | Joined: Aug 2003 Posts: 19 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 19 | The bolt spacing on the rochester is wider. The engine might not be original. It is definatly splash oil, but it could be a 216 or a 235. Did they have different intake manifolds between the two engines. 1937 Chevy 1/2-Ton Pickup x31940 Chevy 1/2-Ton Pickup1940 Chevy 1 1/2-Ton COE1941 Chevy 1/2-Ton Pickup1941 Chevy 1 1/2-Ton COE1941 Chevy 1/2-Ton Suburban1946 Chevy 1 1/2-Ton COE1971 Chevy 1/2-Ton PickupIn the Stovebolt Gallery | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1950 and later 235s have a wider bolt spacing than 216s.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2003 Posts: 19 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 19 | Is there a carter carb that will fit this wider bolt spacing? 1937 Chevy 1/2-Ton Pickup x31940 Chevy 1/2-Ton Pickup1940 Chevy 1 1/2-Ton COE1941 Chevy 1/2-Ton Pickup1941 Chevy 1 1/2-Ton COE1941 Chevy 1/2-Ton Suburban1946 Chevy 1 1/2-Ton COE1971 Chevy 1/2-Ton PickupIn the Stovebolt Gallery | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Is there a carter carb that will fit this wider bolt spacing? The short answer is: YES The long answer: The size 2 (2 11/16 c-c mounting) was used on the 216, and early 235's. The size 3 (2 15/16 c-c mounting) was used on 235's, 250's, 261's, and 292's. Just because a carburetor will bolt up does not mean it will work. The internal venturi size will vary, based on the displacement. Very first thing to do is determine EXACT engine size and year. Then you can look for a carburetor that will function well with the engine. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Aug 2003 Posts: 19 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 19 | The motor is a 1952 216 GM 3835794. The stud spacing is 2 15/16. Any ideas on locating a carter that will work. 1937 Chevy 1/2-Ton Pickup x31940 Chevy 1/2-Ton Pickup1940 Chevy 1 1/2-Ton COE1941 Chevy 1/2-Ton Pickup1941 Chevy 1 1/2-Ton COE1941 Chevy 1/2-Ton Suburban1946 Chevy 1 1/2-Ton COE1971 Chevy 1/2-Ton PickupIn the Stovebolt Gallery | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | It looks like someone has installed a later-model 235 mainfold on your 216. That's possible with a set of stepped-down alignment rings in the intake ports. You'll probably need to find a 216 intake, and then get the correct-size carb for a 216 engine. Even if you find a carb that fits the manifold, it's not likely to be calibrated to work with a 216. Jerry
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Don't jump on me for this, but 19ci between a 216 and 235 isn't that big of a difference and any of the 235 era carbs should work reasonably well. I prefer the Carter YF over the Rochestor B. It's a great carb and easy to work with, but there were many variations of that same carb over a span of years.
Jeff | | | | | Joined: Aug 2003 Posts: 19 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 19 | I have a 1937 W-1 and a matching intake. Will the intake bolt on to the 52 exhaust manifold?
Or what YF would be a fit on my 216 with 2 15/16 spacing?
