9 members (Otto Skorzeny, FishinToms53, 3B, FAST55, Rusty Heaps, MickeyP, pauld, Forty9, 1 invisible), 107 guests, and 2 robots.
Topics128,115
Posts1,056,628
Members48,450
#762158 07/13/2011 6:40 PM
Had a cooling system all apart, now put back together and I have coolant leaking up through the boltholes. I'm wondering if the gasket maybe got ripped near a bolt.
Could I just pull the bolt and coat it in Permatex and put it back in?
"Happiness equals reality minus expectations" - Tom Magliozzi
back yard wrench turner
That might work. A T-stat gasket is real cheap and a correct fix.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
If the bolts go into where water flows always put some sealer on them. Its just good insurance. If the "mating surface" is rough or pitted I'd rub a little sealer on it to even with a new gasket.
Agree with that, replacing any of those gaskets is an easy inexpensive task Jim. I'd just take a fifteen minutes, pull it apart, clean it up real good and put in a new gasket using some Permatex #2. The only way you could have water leaking up thru the bolt is if the gasket is damaged as you already suspect.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Ex Hall Monitor
Ex Hall Monitor
Denny Graham
Sandwich, IL
Yeppers.
