1 members (JW51), 115 guests, and 0 robots.
Topics128,081
Posts1,056,078
Members48,434
#738505 04/12/2011 5:31 AM
1 Offline
I took apart my 1953 wiper motor and re-greased it, now when i hook it up to my truck... when i open the valve all the way the motor springs the wiper arm control arm all the way to one side then stops. Then when i close it, it slowly moves the arm all the way back the other way. if i keep opening and closing it, this will continue. What could be the culprit of this?
I am purely guessing, there is a fabric, maybe leather inside. Could this be dry? I remember siphoning 3 and 1 oil into the motor to make it work. That was 40 years ago. You manually manipulate the motor going back and forth. I think I used a rubber hose and sucked up the oil into the diaphragm. I hope someone else knows how to do it, I am sure mine is going to need repair too
GMONIZ #738530 04/12/2011 12:25 PM
I have a rebuild of a wiper motor on my photo bucket,also if you're glass was dry they don't work so good ,I spray water on the glass to check.
Pete
Pete52 #738541 04/12/2011 1:53 PM
Did you read this recent thread discussing a similar issue? If not, you might want to digest the information. Few vacuum wiper problems are new around here- always seems to be the same things since there aren't many parts in the assembly...
TxLaTx #760454 07/07/2011 11:43 AM
Leo Offline
Moderator
Moderator
I was determined to get my vacuum wiper going too, I even bought a NOS wiper motor, also a 1953. It did exactly what you describe so I finally gave up and bought the electric motor. End of problems.
This refers to a 48 passengers car but perhaps your wiper unit is similar.
Last month I also dismantled cleaned and lubricated the vacuum motor.With reinstalling it it behaved the same as yours.
After closer examination I found out that one of the rubber hoses was too old so it should not sit properly resulting in a vacuum leak.I relapsed all hoses with new ones and now it works perfect.
Jianis
Jianis #760568 07/07/2011 10:12 PM
Forget electric wipers if you are still 6 volt, in my experience. Tried 3 that claimed to be functional on 6v. Sent 'em all back. Some wouldn't even fit! My vacuum motor went to Chevs of the 40's for rebuild, and came back good as new.
Kermit #760571 07/07/2011 10:37 PM
This guy does a great job on these vacuum motors... Ficken Wiper Service
Pete52 #760591 07/08/2011 12:01 AM
Pete
Pete,
Thats a real nice tear down. You should write up a tech tip for that!
Jeff
My 1953 Chevrolet
1947.1 Gallery
Used Ficken for my 54 works great and i also have a dual action fuel pump, got it at auto zone for about $75.00.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
