0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Didn't want to high jack the other thread but here is my question.
I have my wiring harness but for the time being I "hot wired" or straight wired it so I can move it around. I have it so that when I turn the switch on the electric fan runs and the only other wires I have are the ones that are switch to battery, to the starter, the distributor(internal coil). No other wiring is done so nothing to alternator ect. ect. When I turn the ignition switch off the engine continues to run for say 3 or 4 seconds. What makes it do this... is it "feed back" from the electric fan since it continues to turn till it coasts down???
At this point its just my curosity more than anything else.
EDIT: this is a 305 V8
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Only way to confirm it would be to disconnect the fans and see what happens! Scott | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | thanks Scott. Duhh, sometimes I just go brain dead. I guess I'm "too close" to the forrest to see the trees! Thats what my nephew suggested this morning. Hope you and Teresa are doing great. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | thanks Scott. Duhh, sometimes I just go brain dead. I guess I'm "too close" to the forrest to see the trees! Thats what my nephew suggested this morning. Hope you and Teresa are doing great. ....you mean Sherry????...I hope, haha Scott | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | OOOPs, dang, its hard to keep EVERYONE straight. Perhaps if I call you John along with Teresa it'd made more sense. Tell Sherry I apoligize. :mad:
..Scott, just for comfort, I have a good friend, who is a stovebolter that I see regularly. His wife is named Angie but I keep saying Pam....for 5 years!!
Its OLD age creeping up on me. Thanks for being a sport. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You probably do but do you have a relay on the fans?
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | No BigChevy I don't. This is just a temporary thing till I get started on the wiring harness next week. I was just intriqued by the way it does it. I've left it like it is for now but when I start wiring it I plan to put a relay in line with it.... and I'm gonna unplug the fan and see if it does it. I'm just curious! | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | My $.02 I think you will need a diode on the alternator exciter wire regardless. All of my early Motor Manuals for Chevy cars show a diode either connected to the alternator or on the exciter wire. If you do not, the exciter will will feed back thru the ignition switch and you will have run on, just like I did on my '62. Radio Shack has them for under five bucks. Just get the "biggest" one they have like I asked for (as you can see, I am not an electrician). | | |
