2 members (Phak1, TUTS 59), 75 guests, and 8 robots.
Topics128,187
Posts1,057,211
Members48,465
Anyone have any suggestions on replacing the main wire from the igintion switch that runs thru the aroumor cable to the coil. I cut the aroumor cable but it doesn't appear to be a way to replace the wire. I know someone out there has a trick of some kind. Thanks
U
U Offline
not sure what aroumor cable is do you meam armored cable? either way just run a new cable direct from ign switch to coil
. has it got a ballast resistor need more information
Ex Hall Monitor
Ex Hall Monitor
T Online: Content
It's really too bad you cut the electrolock. It's unnecessary and it's not difficult to rebuild one. You can pick up a replacement on ebay if you want to keep it original. If you don't care about original and just want a new wire post your e-mail addy & I'll send you a couple of pics along with a description on how to rewire your electrolock.
Thanks for the information, if you could send me some pics that would be great. I cut the cable, but it would be any easy reweld.
[email protected]
Thanks again
I still might have the original from my 37 around here somewhere,I am planning on going back to a foot stomp starter in the future but will still use the 53 olds ignition switch I have in the truck now.
Ex Hall Monitor
Ex Hall Monitor
T Online: Content
[email protected]
Thanks again
OK, what I'm sending you is a copy of an email with a few pics & instructions that I sent some time back to a fellow needing some assistance. You'll see the wrong name on the message and that's the reason. Check your inbox, it's on the way.
I found the one from my 37.
Ex Hall Monitor
Ex Hall Monitor
T Online: Content
Ward, if you and Jeff can get together & make a deal you'll have a much better result that with trying to weld the cable back together.
