8 members (1955 1 Series, Rusted Nut, Otto Skorzeny, cmayna, Pre '68 Dave, Gdads51, Joe H, 1 invisible),
97
Mod | | | Forums66 Topics128,192 Posts1,057,251 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Anyone have any suggestions on replacing the main wire from the igintion switch that runs thru the aroumor cable to the coil. I cut the aroumor cable but it doesn't appear to be a way to replace the wire. I know someone out there has a trick of some kind. Thanks | | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | not sure what aroumor cable is do you meam armored cable? either way just run a new cable direct from ign switch to coil . has it got a ballast resistor need more information | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | It's really too bad you cut the electrolock. It's unnecessary and it's not difficult to rebuild one. You can pick up a replacement on ebay if you want to keep it original. If you don't care about original and just want a new wire post your e-mail addy & I'll send you a couple of pics along with a description on how to rewire your electrolock.
| | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Thanks for the information, if you could send me some pics that would be great. I cut the cable, but it would be any easy reweld. [email protected]Thanks again | | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | I still might have the original from my 37 around here somewhere,I am planning on going back to a foot stomp starter in the future but will still use the 53 olds ignition switch I have in the truck now. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Thanks for the information, if you could send me some pics that would be great. I cut the cable, but it would be any easy reweld. [email protected]Thanks again OK, what I'm sending you is a copy of an email with a few pics & instructions that I sent some time back to a fellow needing some assistance. You'll see the wrong name on the message and that's the reason. Check your inbox, it's on the way.
| | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | I found the one from my 37. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Ward, if you and Jeff can get together & make a deal you'll have a much better result that with trying to weld the cable back together.
