1 members (1955 1 Series), 64 guests, and 4 robots.
Topics128,169
Posts1,057,102
Members48,463
Anyone have any suggestions on replacing the main wire from the igintion switch that runs thru the aroumor cable to the coil. I cut the aroumor cable but it doesn't appear to be a way to replace the wire. I know someone out there has a trick of some kind. Thanks
U
U Offline
not sure what aroumor cable is do you meam armored cable? either way just run a new cable direct from ign switch to coil
. has it got a ballast resistor need more information
Ex Hall Monitor
Ex Hall Monitor
It's really too bad you cut the electrolock. It's unnecessary and it's not difficult to rebuild one. You can pick up a replacement on ebay if you want to keep it original. If you don't care about original and just want a new wire post your e-mail addy & I'll send you a couple of pics along with a description on how to rewire your electrolock.
Thanks for the information, if you could send me some pics that would be great. I cut the cable, but it would be any easy reweld.
[email protected]
Thanks again
I still might have the original from my 37 around here somewhere,I am planning on going back to a foot stomp starter in the future but will still use the 53 olds ignition switch I have in the truck now.
Ex Hall Monitor
Ex Hall Monitor
[email protected]
Thanks again
OK, what I'm sending you is a copy of an email with a few pics & instructions that I sent some time back to a fellow needing some assistance. You'll see the wrong name on the message and that's the reason. Check your inbox, it's on the way.
I found the one from my 37.
Ex Hall Monitor
Ex Hall Monitor
Ward, if you and Jeff can get together & make a deal you'll have a much better result that with trying to weld the cable back together.
