0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#751535 06/02/2011 6:29 PM
ok so i took out the ignition from my 1950 GMC becuase the guy i bought it from didnt have the key and i want to see if it turns over now would any one know how i can hot wire it ti check?
1950 GMC 1 ton 250 series
GMC_one_ton #751538 06/02/2011 6:33 PM
just connect those wires you took off the back of the switch.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
It can be hot wired without removing the switch. But since you have it out, do what Vern said.
Then pull the lock out of your door, record the code number off the housing and have a new key cut.
Cletis #751567 06/02/2011 9:11 PM
To see if it turns over no key, ignition switch, or hot wire is necessary. Just press the foot starter button on the floor.
For it to run (and all the lights to work) connect together all the wires on the back of the ignition switch. Note that this hot wire method works because the starter is not a function of the key switch.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #751649 06/03/2011 3:36 AM
well the ignition broke when i took it out so hooking it back up aint a option and i try just pushing the foot pedeal and had nothin so i will check the wireing and try again ... thanks
GMC_one_ton #751686 06/03/2011 5:09 AM
i got it thank you!! but she is sezied and i put oil in the plug holes like 3 days ago and it aint workin.. any ideas???
GMC_one_ton #751798 06/03/2011 6:44 PM
For one thing, it'll take longer than three days. There are plenty of threads on this forum about seized engines. Do a search and get ready to do some reading.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Rich'sToys #751808 06/03/2011 7:19 PM
My grandpa found the cylinder that was on the compressoin stroke and hooked up an air hose connector to a pipe fitting the same size as the spark plug threads (drilled out an old plug and brazed the fitting on it)hooked it to the air compressor and it turned the engine backwards until air came out the intake. Then diesel and oil in each cylinder and slowly worked it til it turned over very easy without any plugs in it.
I may be young but I'm willing to try and learn, which is better than being old and thinking you know it all... I'm looking in your direction dad.
TristenRichter #751816 06/03/2011 8:02 PM
As you try to unstick the engine forget about using the starter until it turns freely once again, no need to burn up a starter too.
To turn it over, or attempt to, you can pry on the ring gear when necessary.
---All pictures---
Grigg #751849 06/03/2011 10:47 PM
use Kroil penatrating oil in the cyclinders if no work you have trouble.breake fluid works also.how long has it been setting???.where .Hot Wire ,one wire form ign side of coil to positive battery post.thats it.ready to start
dan-pa
