4 members (Steelonsteel, TooMany2count, 6inarow, klhansen), 86 guests, and 1 robot.
Topics128,035
Posts1,055,552
Members48,425
#74965 03/18/2007 1:40 PM
2 years ago driving down road valve drops,hole in head, distroyed piston blown up engine-Problem valve set eat away 350 chevy. New motor-2nd time cam shaft lobe flat, bad valve seat-new cam, rebuilt head 350 chevy. Third time driving down road valve drops-blown engine 350 chevy. Whats up? Is Roush racing making all my chevy motors and part's? Going to have to put in another motor. Any one know of other's having this many problems on one truck?
#74966 03/18/2007 2:25 PM
Riding in the Passing Lane
That is some bad luck. It,s pretty rare a small block drops a valve. I hear there is some problems with cam-lifter wear because the oils don,t have the additives for flat tappet cams since newer cars are using roller tappets. They recommend using deisel oil. I just buy a new Goodwrench engine for all I do. Everything is new & factory built.
1972 Chevy c10 Cheyenne Super
#74967 03/18/2007 3:00 PM
I had a bus load of kids and adults on a Chevy bus with a 350 that dropped a valve 30 miles from home. Engine was running fine, no hint at trouble.
The second I heard the noise I hit the clutch and switch, but it was too late, the damage was already done. There was absolutley no warning this was going to happen. (This was a rebuilt engine that came in the bus)
#74968 03/18/2007 3:49 PM
who's doing the heads for you.. ohwell
#74969 03/19/2007 1:55 AM
3 different places. 1 new rebuilt long block 2nd set off previous teardown 3rd machine shop. Noticed two engine failures today on NASCAR, valve problems,unleaded gas? come on guys whats up? Going down for 4th engine here shortley. What am I missing? Should I run a 1/2qt. Diesel with tank of gas to keep from knocking seats out? :confused:
#74970 03/19/2007 3:43 AM
Stop walking under ladders, dont cross the black cats path, and stop breaking mirrors! Thats some seriously bad luck. But thats all Id equate it to. Good luck on the next engine.
My 1953 Chevrolet
1947.1 Gallery
