4 members (Ricks Big Dump, Donf, Peggy M, 1 invisible), 148 guests, and 3 robots.
Topics128,086
Posts1,056,101
Members48,434
#749459 05/24/2011 6:50 PM
Does anyone have a good reliable source for 3 speed synchros? I found them rebuilt/new for $285. Ouch!
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #749517 05/25/2011 12:12 AM
Do you have a 53 and earlier or 54 and later. The later ones have 4 lugs and the earlier have 2. There is a new later one on eBay for $200. If I remember correct, 2 of the lugs can be ground off. The one on eBay can be found by searching 1957 Chevrolet transmission on eBay.
crenwelge #749530 05/25/2011 1:03 AM
R Online: Content
Anaheim Gear has them for the SM318 (55 up) they may have the earlier style also. 800-477-1103
Fred
rfs56trk #749896 05/26/2011 2:28 PM
Thats what I had to do to mine ,grind off the two smaller lugs ,I got mine from Jim Carter when I was at the reunion last year ,went for a visit of the store and found a brand new one on the shelf ,got home and rebuilt the trans.Just take the old one and you'll see what you need to grind it's easy.You will have to make three tools to get it all apart and back together.If you PM me you're e-mail I'll send you the pics of the tools I made ,one is an open end wrench ,needs to be thin ,and the other is a pc. of 1 1/2 angle iron with a hole in it to mount to the rear of the trans to remove the output shaft and than pull it back into the bearing inside the trans and last you have to make a spreader to remove the lock ring for the bearing thats inside the trans for the output shaft.
Pete
Pete52 #749940 05/26/2011 9:28 PM
Dave, what year transmission is this?
Jeff
My 1953 Chevrolet
1947.1 Gallery
rustednuts #750317 05/28/2011 10:56 PM
I'm pretty sure the tranny is original 53'. Got the truck out today for a few warm up laps and it is running OK but not fantastic after sitting covered up all winter. A great deal of humidity has collected and minor rust is showing up. darn. I jst don't feel like puting the spit shine on it again this year.
Thanks for the info gentlemen.
Dave
53moneypit #750481 05/29/2011 6:59 PM
Dave,
Check out the Filling Station part #RW-453. These are the two synchronizer rings needed at $35 each. Are you looking for the whole assembly with the synchronizer drum and synchros?
I rebuilt the 3spd transmission in my '53 several years back at $90 for the full kit, minus $20 each for the synchros. Seems prices have skyrocketed in just a few years...
I have the shop manual for overhauling scanned if you need it. PM me if interested with your email address.
Jeff
My 1953 Chevrolet
1947.1 Gallery
