5 members (MickeyP, dt235sd, Wally / Montana, JW51, Bill Hanlon), 58 guests, and 2 robots.
Topics128,049
Posts1,055,699
#742755 04/27/2011 12:47 AM
Hello Stovebolters
Has anyone had the problem of a throttle that is so touchy that when starting off in low gear the truck starts bucking like bucking horse. (I know how to drive stick)the only way to stop it is to push in the clutch and start over again.I'm driving a 1949 3100 216 with a single barrel carb.
bill1949
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
bill1949 #742758 04/27/2011 12:58 AM
Tink you may need motor mounts Bill.
DG
Denny G
Sandwich, IL
All new mounts were insalled when put the engine in
May not be the throttle, there's a possability that you may have a timing issue. It may need to be advanced a bit. Not a whole lot, maybe 5-10 degrees. You'll also want to make sure you have no vacuum leaks.
Bill Burmeister
Is all the linkage stock?
panic #742842 04/27/2011 6:42 AM
Does the rod have clearance where it goes through the toe board? What about your clutch and clutch linkage?
Could this be clutch chatter from oil on the clutch disc, or a mal adjusted clutch?
I had the same problem with my previous Rochester B. It was the early model with the thin top. When they redesigned it, a year or two later, they made some modifications to stop the "hesitation". I have a 1952 model on now and it is completely smooth.
1951 1 Ton Completed
I don't know if this would apply to a truck, but I once had this problem caused by a broken seat mount in a 52 Chevy sedan.
When the car accelerated in low gear, the seat would rock back slightly. This would lift my foot off the throttle. The car would then decelerate, causing the seat to rock back forward. This would drop my foot back onto the pedal, and the cycle would repeat.
Kinda fun when your 15.
I suggest you take a moment to rule out this possible cause before spending any serious time or money.
regards,
Leon
Leon #742871 04/27/2011 1:55 PM
Are you starting out in granny gear? Try using 2nd for starting out instead. Granny gears are for heavy loads. Another point might be to use less throttle when disengaging the clutch.
Builder #742901 04/27/2011 4:31 PM
Bill,
On my fire truck with a 216 and Carter single-barrel carb, my engine bucks like you describe unless I have the choke pulled out about a 1/3rd. Clearly a lean condition, working on checking the jets/float.
Try it anyway, see if it makes a difference?
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Builder #742940 04/27/2011 6:32 PM
I had a problem with my 58 with a 350,th350 throttle linkage. When stopped at a light and stepping on the brake, the engine would speed up. Taking it out of drive and the engine speed would return to idle. The problem was with the throttle linkage, when stopped at the light the engine torque caused the linkage to open the throttle slightly which caused more torque and more throttle.(Justlike a run away Toyota) This was caused by not having enough play in the linkage. Fixed this by adjusting the linkage longer to make more travel in the accelerator pedal.
You might check linkage when the clutch engages,the engine torque may cause the throttle to open and make it difficult to drive.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
