| | | Forums66 Topics128,057 Posts1,055,814 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | Hello Stovebolters Has anyone had the problem of a throttle that is so touchy that when starting off in low gear the truck starts bucking like bucking horse. (I know how to drive stick)the only way to stop it is to push in the clutch and start over again.I'm driving a 1949 3100 216 with a single barrel carb. Thanks bill1949
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tink you may need motor mounts Bill.
DG
Denny G Sandwich, IL
| | | | | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | All new mounts were insalled when put the engine in
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | May not be the throttle, there's a possability that you may have a timing issue. It may need to be advanced a bit. Not a whole lot, maybe 5-10 degrees. You'll also want to make sure you have no vacuum leaks.
Bill Burmeister | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Is all the linkage stock? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Does the rod have clearance where it goes through the toe board? What about your clutch and clutch linkage? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Could this be clutch chatter from oil on the clutch disc, or a mal adjusted clutch? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had the same problem with my previous Rochester B. It was the early model with the thin top. When they redesigned it, a year or two later, they made some modifications to stop the "hesitation". I have a 1952 model on now and it is completely smooth. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I don't know if this would apply to a truck, but I once had this problem caused by a broken seat mount in a 52 Chevy sedan.
When the car accelerated in low gear, the seat would rock back slightly. This would lift my foot off the throttle. The car would then decelerate, causing the seat to rock back forward. This would drop my foot back onto the pedal, and the cycle would repeat.
Kinda fun when your 15.
I suggest you take a moment to rule out this possible cause before spending any serious time or money.
regards, Leon | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Are you starting out in granny gear? Try using 2nd for starting out instead. Granny gears are for heavy loads. Another point might be to use less throttle when disengaging the clutch. | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Bill,
On my fire truck with a 216 and Carter single-barrel carb, my engine bucks like you describe unless I have the choke pulled out about a 1/3rd. Clearly a lean condition, working on checking the jets/float.
Try it anyway, see if it makes a difference?
-Michael | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | I had a problem with my 58 with a 350,th350 throttle linkage. When stopped at a light and stepping on the brake, the engine would speed up. Taking it out of drive and the engine speed would return to idle. The problem was with the throttle linkage, when stopped at the light the engine torque caused the linkage to open the throttle slightly which caused more torque and more throttle.(Justlike a run away Toyota) This was caused by not having enough play in the linkage. Fixed this by adjusting the linkage longer to make more travel in the accelerator pedal. You might check linkage when the clutch engages,the engine torque may cause the throttle to open and make it difficult to drive. | | |
